Question about Canon MV930 Mini DV Digital Camcorder
Unable to capture
Despite all my efforts i couldnt get my mv930 detected by the computer. I had to buy a iee1394 pci card as my motherboard didnt have the firewire port built in. When i connect the camera to the pc nothing happens. I tried 3 different cables but still no luck. I tried all combinations possible: with the camera powered on AC, on batteries, camera switched off when connected to the pc, the camera switched on when connected with the pc etc. I went to the service and on their test computer it worked. It was about 1 year ago. Since then i continued trying, i installed the iee1394 card on 2 computers at work and still no luck, i also went to a video studio and strangely the camera didnt work there either. As i didnt find anything related on the forums im starting to think that i burned the firewire port on the camcoder. Any help would be appreciated, thanks.
4 Suggested Answers
SOURCE:
Bubbabear64
  • 2794 Answers
SOURCE: Unable to tansfer video to computer using DV cable..
Pinnacle software will recognize the camera installed through a firewire cable once the camera is turned on. Windows movies software doesn't recognize DV cameras. You may be able to get capture to work if you go to Microsoft.com and download the Windows Media 9.0 Development Kit. I believe DV input is a capture option.
There has to be a 3rd party program installed to get it to recognize it.
Good luck on that.
Posted on Jun 09, 2008
  • 435 Answers
SOURCE: Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable. http://cdn.overstock.com/images/products/L10726964.jpg
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Posted on Sep 24, 2008
  • 15 Answers
SOURCE: Firewire worked once but not anymore...Canon XHA1
Solution? Maybe, but PC's vary greatly. Pass it on if it works for you. If Win-XP. Device manager. Un-install IEE1394. Close & Restart. Let the system restore the 1394 then try to reconnect the unit, cable to the PC first, then to the powered down camera. Power up the cam. What are you using to ingest? I recommed http://scenalyzer.com.
Posted on Jan 14, 2009
Sony CCD-TRV438E Hi-8 Analog Camcorder i need driver to connect with my pc
You need to buy a TV card which comes with audio /video composite sockets. these are female RCA or phono sockets which are also found on your camera.TV cards come with their own software to be able to capture pictures from your Hi 8 Camcorder using the av cables like the ones you use from your DVD to your TV set. There are other cards which carry the av sockets and come with video capture software. These cards are usually PCI cards which are fitted into your PCI slot in your PC motherboard. One other software that comes with such a card is Pinnacle Studio. Its called the Pinnacle AV/DV pci capture card. The one I use is just a DC 10 which works with Studios version 8. Please try any of these cards for your video capture
Oct 28, 2011 | Sony CCD-TRV438E Hi-8 Analog Camcorder
I need to connect a Sony trv950 camcorder to Adobe cs4, it only accepts firewire to capture video. and the emachine only has usb ports
You can buy a PCI card for firewire and put it inside your PC case in an empty PCI slot. They are pretty cheap. In Canada / USA you can get them for about $30 from your local computer store, best buy etc..
Here is a link to best buy USA: http://www.bestbuy.com/site/Dynex%26%23153%3B+-+3-Port+FireWire/IEEE+1394+PCI+Card/6307392.p?id=1074787927900&skuId=6307392&st=firewire%20pci&cp=1&lp=1
Regards, Chris
Jul 01, 2011 | Computers & Internet
SoundBlaster Live 24-Bit PCI Sound Card Installation
Kindly remove the sound card out from your motherboard. Power on your computer and then go to BIOS settings. Look there for a settings relating to Audio device and then turn it off . The audio device in your motherboard will now be disable. Plug in back your soundblaster sound card, power on your computer and then install the driver for it.
Dec 17, 2009 | ASUS M2N68-AM SE2 Motherboard
Camera not detected on firewire port
it will only be detected in a Video Capturing Software , select ur camera options menu and check for the output mode needs to be DV studio or somethn glike that
and then go to the capturing software ur camera will be detected as DV device when in capturing mode turn on the camera and select device from teh drop down list
which capturing software u are using kindly ask me for exact info on that
Nero
Ulead
Cyberlink or what
kindly rate me WELL !
May 17, 2009 | Intel Computers & Internet
Device detection
Need to check bios first for any on board sound auido devices that are enabled and disable it. Try to restart windows and see if detects. If it doesn't work then try to move the sound card to another slot on motherboard and restart computer.
Aug 09, 2008 | Aureal MTC Vortex Advantage PCI Sound Card
Tv card & Capture that support intel motherboard dg31pr
The Intel DG31PR motherboard has one PCI-Express x16 slot & two PCI slots. The motherboard also has 1 PCI-Express x1 slot.
You can use any of these slots. I am guessing you are using the PCI-Express x16 as you're primary video display. If you're not using the PCI-Express x16 slot & using the onboard graphics you could use anyone of these PCI-Express x1 capture cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3493&name=PCI-Express-Video-Capture-Cards
For the PCI slot (Two whit in color). Any one of these.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1425&name=PCI-Video-Capture-Devices
Video capture devices include a learning curve. Do not expect to add one of these into you're system without reading the instructions. (I know little of this format). The PCI-E x1 will be faster than the PCI cards.
I hope you found this helpful!
Good Luck!
Mike
Jul 15, 2008 | Intel DG31PR Motherboard
Problem connecting JVC GR D370U
I have JVC GR-D270 cam how I can copy my video from tap to my Laptop
Sep 27, 2007 | JVC GR-D370 Mini DV Digital Camcorder
I have problem Video Capture form VHS
Try another computer and use that one to see if it would isolate the issue for your computer.
May 29, 2007 | ATI All-in-Wonder 2006 PCI Express ,...
Canon MV930 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
