Question about Jandy Pro Series VS FloPro 2HP Variable-Speed Pool Pump - 208-230V
Been running now won't start
Motor won't start
My A/c won't start
Have an electrician check the capacitor in the unit as the motor will not run if it has failed.
Jun 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Won't start
sounds like you have a bad motor,when it heats up it stops running and when it cools down it will run again but one of these times it won't run anymore until you change out the motor.when the motor gets hot you might smell a shellac smell,this is the windings on the motor heating up.part number 8528157 and it's around 120 dollars on the sears site
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-LSQ9549LW3/1198/0153200/W0312163/00005?blt=06&prst=&shdMod=watch this video to change motor
http://www.youtube.com/user/RepairClinic?v=Oeiyjt7807o&feature=pyv&ad=5457341981&kw=washing%20machine%20motor
May 07, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
My serger won't start. Motor is running but won't turn. Also wheel wont turn
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
Jun 05, 2011 | Husqvarna Huskylock Computerized 905
Jandy Pro Series VS FloPro 2HP Variable-Speed Pool Pump - 208-230V Logo
26 people viewed this question
Top Jandy Plumbing Experts
Donni Steen
Tom Chichester
Are you a Jandy Plumbing Expert? Answer questions, earn points and help others
