Question about Poulan Pro PRRT850 17 Tine Tiller
Gear shift BROKEN
NO CABLE CONNECTION TO GEAR SHIFT
Victory motorcycle won't shift and the transmission just revs up but won't shift or move, the clutch won't put bike in gear to move
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Shifting Problem
Shifting issues
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=13620&start=1
Victory Motorcycle Tranny Cover Disassembly Shifter replacement
Witchdoctor How to adjust clutch cable on Victory motorcycle
Jun 18, 2017 | Victory Motorcycles
1984 Yamaha venture royale 1200 stuck in 4th gear
Hi, Michael and the usual suspects are:
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Stuck in 4th Gear 1995 Sportster 1200 Harley Davidson Forums
ATV Connection
http://bergall.org/temp/venture/pdf/1983-1985-yamaha-venture-manual-complete-with-wiring-diagrams.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xv-owners-manuals
Feb 20, 2017 | Yamaha Royal Star Venture Motorcycles
I have a 1996 Volvo, when i place the gear shief in any gear, itconnect to the transmission, what do i need to do?
If automatic, there may be a connection broken between transmission and gear shift. I assume you have checked the transmission fluid level. I assume your emergency break is off. If not it may be quite low and you need to fill. That would also indicate a bad leak in the transmission.
If Standard transmission you may have a clutch problem or again a broken connection between gear shift and transmission.
Feb 13, 2015 | Cars & Trucks
Gear changer stuck and gears won't change
The cable for the chain shift mechanism (derailleur) has slipped or broken. The cable will need to be loosened down by the chain then put your shifter in the position closest to the gear it is actually in, then pull the cable snug and hold it while you tighten the cable. This will also verify that the cable is working. There are position limit adjusters so the shift mechanism should be in the correct position on one of the gears when there is no tension on the cable.
Apr 07, 2014 | Specialized Rockhopper
I can shift into drive but it won't engage
sounds like a broken shift cable. (the connection between the shifter and the gearbox) common symptoms are the shifter move easier than normal.and does not move to any gears (not even park or neutral).
Nov 23, 2013 | 2004 Chevrolet TrailBlazer
Gear shift has too much play in it.
Check the shift linkage/cable to see if it is broken, loose, disconnected, or binding.
Mar 17, 2013 | 2007 Ford Explorer Eddie Bauer
How difficult is it to change the shifter cable
Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
5
Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
6
Test the functionality of the shifting cable by moving the gear shift in and out of gear.
Jan 03, 2013 | Saturn Cars & Trucks
How to install a transmission shift cable in a 2000 Cavalier
    • 1 Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
    • 2 Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
    • 3 Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
    • 4 Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
    • 5 Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
    • 6 Test the functionality of the shifting cable by moving the gear shift in and out of gear.
Sep 23, 2011 | Chevrolet Cavalier Cars & Trucks
18 speed bike 6 gear shift works fine 3 gear
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
May 09, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Gear shift will not move . button on gear shift does not press into move gear shift out of park.
connection under shifting housing, broken??
there is a release button there as well will bypass the connection
Nov 21, 2009 | 2008 Chevrolet Impala
Poulan Pro PRRT850 17 Tine Tiller Logo
54 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
