Question about Hauck Apollo 4 All In One Travel System in Sky
Spare parts front bar for push chair
Hi, my mother's mobility scooter won't work. The power button flashes constantly. Any ideas how I can fix it?
Many times a brake lever reset can resolve this issue that is preventing the PWC from operating.
MPV5 Power Wheelchair Break LeversMPV5 – The brake levers are located on the front of the Power Wheel Chair just above the footplate. To reset the brakes on the MPV5 Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
FWD and XHD power chair break releaseTEK FWD and TEK XHD - The brake levers are located on the front of the Power Wheel Chair under the label that reads “Drive” and “Push”. To reset the brakes on the TEK FWD or XHD Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
If the lights on the controller continue to flash make sure the controller is not locked.
Apr 14, 2016 | Health & Beauty
What is the best material for an electric massage chair?
most chairs are made out of leather, vinyl, or some kind of synthetic leather. In general, vinyl is the best material because it is the most able to stretch (from the massaging bars pushing on it repetitively) and the best at handling heat (which is included in most massage chairs). Leather will begin to crack after some period of use, because it is not as susceptible to stretching
Dec 25, 2012 | Furniture
Where can you buy replacement straps for quinny buzz 3 push chair please?
Hi
The harness is not available as an individual spare part item. It is sewn into the sub seat (seat frame) To replace the harness you would need to replace the sub seat.
Please contact us directly on our FB page to discuss further -
Dorel UK Customer Service
Aug 31, 2011 | Quinny Buzz 3 Stroller
On the TiLite Aero X, I would like to add a bar or rod of some kind on the lower back of the chair for the person pushing the chair to push down on to tilt up the front of the chair. Is there a name for...
There are push cane handles that are made to attach to the horizontal reinforcing bar of the back H frame. To visualize this part think of a tube of straight metal bent at a right angle 6 inches from the end. The end of the straight section fits into the top of a clamp which is secured to the horizontal part of the H of the back frame. These push handles are usually installed as a pair so an attendant can push the chair from behind. They can also be used for what you are describing.
Tilite calls these push handles. The different types and lengths that are available can be viewed at this link:
http://estore.tilite.com/ecommerce/CatalogSubCategoryDisplay.aspx?CID=612
You might also look at the stroller handle section and see if that may all help.
Hope this helps
Jan 08, 2011 | Tilite ZRa Titanium Wheelchair
Where can i get new tubes for push chair
Here's a site in Holland that sell's all types of stroller tires www.babycare.nl/spare-parts-banden-c-34_124_149.html Check site to confirm size then check local bike shop to see if they can get one before you pay for international shipping.
Dec 13, 2010 | Graco Baby Gear
The bar in between the handle bars has snapped can
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
Oct 13, 2009 | Quinny ZAPP Stroller
Pride Lift Chair
Yes, jump, short, somehow bypass the switch and see if the chair moves. In 4 of 5 cases, I have had to replace the switch. Its the only part I carry with for "spares". Its an easy fix, and a lot cheaper than replacingt the whole hand control.
Feb 02, 2009 | Pride Mobility Products Casual CL30KD Lift...
Hauck Apollo 4 All In One Travel System in Sky Logo
26 people viewed this question
Top Hauck Baby Gear Experts
Kelley Hopper
ray gallant
Dorel UK
Dorel UK
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
