Question about Toto Home
Water Spraying From Top of GMAX Flushing System Antisiphon
I have a 1.6 Gph Toto Toilet with GMAX Flushing System - Anti siphon. When I flush the toilet, water sprays from the top of the Anti Siphon. What is the fix for this?
2 Suggested Answers
  • 33 Answers
SOURCE: Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Posted on Jan 07, 2010
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
The toilet makes a very loud, high pitched noise when flushed.
I recently had the same problem. to let you know I replaced the filler and the flapper to NO avail. I tried flushing with the water OFF and it still did it thought it was in the siphon so I removed the water going in there and it still made the sound. This AM it got to me so I was determined to be rid of the WHINE It only happens when the TOP is on that is when it hit me is the seal so great that the vacuum creates the whine I put the little rubber door stops, the one you use in door jams, on the four side and tada no more sound Hope this helps
Dec 26, 2009 | Toto Drake ADA Compliant Toilet with...
Leak at water supply into tank.
Seams like you have a hair line crack in the intake pipe. I would recomend replaceing it to solve your problem.
Sep 07, 2009 | Home
Toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Jun 20, 2009 | Toto Drake ADA Compliant Toilet with...
Toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto GMax Flushing System drips
What you are experiencing is a flapper valve problem. Since I don't know what model you have I will give you a link to the generic GMax unit. Here is the parts breakdown for a GMax
Toto GMax
I would suspect you need part #7 on this diagram a flapper valve. Take the old one with you since different colors ones are used on different models. You should go to the Toto site to locate a dealer first. You can find their site here:
Toto USA
Hope this helps and please remember to rate this!
Dec 07, 2008 | Toto Home
Home Logo
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
