Question about Hotpoint RVM1435 Microwave Oven
At times some buttons dont work
Recently some of teh buttons have stopped responding, otherwise the microwave owrks just fine. Any help will be greatly appreciated. Thanks.
That was unreal but, it worked for me too. Great tip
Posted on Oct 26, 2007
  • 3 Answers
This may sound crazy but I had one do the same years ago. I cleaned the touch board with glass cleaner and would work fine until got dirty again. Won't hurt to try!
Posted on Aug 11, 2007
Microwave stopped working
Probably a problem with the door latch safety system. This happens every so often with our microwave, which is over 25 years old, and otherwise works perfectly.
If yours is new, it may still be under warranty. If not, there are places that specialize in fixing microwave ovens.
If it is an older, or less expensive oven, it might be time for a new one.
Jul 22, 2014 | Sharp R-1500 Microwave Oven
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
Microwave won't start
Did someone recently clean the front panal with a wet cloth or spray it with cleaner? Was it near a very steamy source? If the touch panal gets moisture between the layers it will no longer work. Some times it will dry out eventually and start to work again. Many times replacing the panal is the only fix.
Eric
Jun 08, 2009 | Whirlpool Microwave Ovens
Works fine before unplugging, stops working when plugged in again
Westinghouse WST3504 User Instructions Before Calling For Service
YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
BEFORE CALLING FOR SERVICE Possible Causes
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work fine, and the light inside turns on. We can enter a cook time, and it counts down as if...
It's one of the micro-switches (3) that are part of the interlocking safety circuit. I actually took my switch apart and fixed it, but 99% of those out there would (and should) replace the switch.
Dec 28, 2008 | GE JVM1330BW/WW Microwave Oven
Suggestions
check the touch pad or control switches, and check the control panel circuit, check the thermal sensors. check the wiring.
Sep 28, 2007 | Westinghouse WST3504 Microwave Oven
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
133 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
