Question about Nespresso U D50 Espresso Machine Color: Pure Black
Reset Cleaned machine and I don't know how to reset it
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
The lower side of thread is looping
Could be your bobben tension need reset.Try that and let me know if it helps.Good Luck.Don't give up!!!
Nov 27, 2011 | Singer 3116 Simple
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Our Sharp ARM455N Copier shows "Maintenance
this is message that the copier did certain amount of copies and it needs to be cleaned and ispected. The purpose of preventive maintenace is to stop or reduce problems before they occure. In most cases they occure when you need the copier urgently.
This can be reseted in simulation mode, but I recommend to get service technician to service the copier.
If you want to reset the alarm leave the email and I'll send you the service manual.
Sep 09, 2011 | Sharp AR-M455N Copier
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Water still does not flow, even after I cleaned it and tried running just water.. don't know what else to try?
water flow very little have cleaned machine but stil the same, also what is the allen key for?
Aug 23, 2011 | Breville Fresca BES860 2Cup Coffee Maker
My A/C just went off yesterday night, it says E2,now i cleaned the filter but i don't know where's the reset button... where is it?
The easiest way to reset the electronics is turn the Master On/OFF Switch to OFF & unplug it for 10 minutes. The plug the unit back in and Turn the switch ON. During that time out, the electronics should have reset and reverted back to the original factory setting. You can then set the controls as you wish.
Hope this was of help and thanks for choosing FixYa.
Aug 21, 2011 | Royal Sovereign Heating & Cooling
I have a vintage PFAFF 30 sewing machine. I was sewing and the needle suddenly stuck down and wouldn't come up even when I turned the wheel. I tried everything i could think of to fix it. But I...
I recently purchased a Pfaff 30 with the sane problem. Local repair shop took it apart cleaned and oiled it and it's as good as new he charged 50.00 fir the repairs
May 28, 2011 | PfaFF Sewing Machines
The Danby Millennium Dehumidifer goes not condense any more. Have unpluged the unit, cleaned all of the filters. Is there a way to reset the unit from the controls?
If you unplugged the heater for 12-15 minutes, after turning OFF the Master On/OFF Switch, the electronics should reset themselves. Also, be sure that you don't have the humidity level set to high. Anything above 60% wont' extract any moisture to speak of. If your unit doesn't have an LED display, set the unit on Minimum.
Hope this helps you. Please let me know. Thanks.
May 17, 2011 | Danby DDR401 Dehumidifier
Nespresso U D50 Espresso Machine Color: Pure Black Logo
44 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
