Question about Hotpoint RVM1425 Microwave Oven
At times some butons don't work
I have Hotpoint RVM1435WD002 and from last couple of days some of the buttons, especially the fan, the counter light and buttons at the bottom row of the panel (at times) have stopped responding. At times everything just works fine. For the buttons that reposnd, the microwave jus works great. Any suggestions will be highly appreciated. Thanks.
  • jenny939 Sep 22, 2008
    I am renting an apartment, so I do not know how old the microwave is. The first week we were there we realized that HALF of the keypad does not work. There is no rhyme or reason to it. the number 7, 8,9 and 0 do not work, the "time cook" button does not work. I do not think the power level button works either. The only way I can use the microwave at the current time is to use express cook options 1-6. I have not bothered the maintenance department about this, as I am hoping there is an easy solution to this-- or I can at least tell them what parts to order.. Help!!
  • Hotpoint Master
  • 9,125 Answers
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
Lights on bottom don't work. Sockets fell apart and vent fan now does not work. A bulb blew out , then all of this happened.
We see and repair this a lot. The problem is on the control board, which we regularly repair for $39.95 nationwide.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We'd also recommend buying top-quality bulbs.
They can blow if subjected to vibration such as door slamming or a weak floor, or electrical fluctuation, especially if they are cheap bulbs or they are left on all night.
Instead of having the board repaired, you can order a new control circuit board / smart board if that's economical, and since your sockets are bad, they will need to be replaced, too.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your
favorites.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're changing the board yourself, you'll need to detach the keypad connector:
Some connectors will have a lock.
Dec 27, 2012 | Microwave Ovens
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
MICROWAVE DOESN'T WORK
32 years from a microwave!! Wow! Time for new. No parts available anymore. The smithsonian may be interested.
Oct 02, 2017 | Montgomery Ward Microwave Ovens
Hotpoint microwave is loud.
your transformer windings are loose and the 60 cycle frequenct is setting up a mechanical vibration, you can try and look for anything loose inside the unit, but if the transformer windings get loose theres really no fix but to live with it
Oct 06, 2009 | Maytag MMV4205 Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
Works fine before unplugging, stops working when plugged in again
Westinghouse WST3504 User Instructions Before Calling For Service
YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
BEFORE CALLING FOR SERVICE Possible Causes
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
Mircowave blew
inside check transformer and heating element
Feb 27, 2018 | Amana ACO1840A Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
273 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
