Question about Welding Tools
Capacitors circuit board
I have a Thermal Dynamics plasma cutter just off warranty that has lost the circuit board. Ii is the cut master 80 or 82. What are my options? Thanks, Kraig. .
4 Suggested Answers
co7196
  • 3433 Answers
SOURCE: the lights are working for power and gas pressure
No, Try changing the tip. The one under thr node cone. If it burns back it will concave and increase the gap between the work and gun tungdten electrode.
Posted on Nov 05, 2009
  • 9 Answers
SOURCE: plazma cutter/no arc
The Cutmaster 50 used two different CD "Capacitor Discharge" Boards. The only ones I have seen a lot of issues with were the smaller ones that are 3.5" X 4"
I have worked on several of the them over the last few months. Even though you might see a spark at the spark gap on the board it might not be sufficient to create a pilot arc.
If your air pressure and so forth are correct your issue is most likely the two white capacitors on the CD board.
Posted on Nov 07, 2009
  • 108 Answers
SOURCE: need 2 capacitors for my plasma cutter 1500uf 240v
Hi, can you send me pictures of the caps, all sides. And also next to a tape measure if possible.
Regards
Posted on Jun 02, 2012
I have cheep chinese plasma cutter cut 50 comes on and does spark got air it will not cut what could be problem
HF spark gap adjustment needs to be done, it's inside the machine, front of bottom circuit board.
Dec 03, 2014 | Welding Tools
Need 2 capacitors for my plasma cutter 1500uf 240v
Regards
Jun 02, 2012 | Lincoln Electric Plasma Cutter, Pro - Cut...
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
How hard is it to change out the main circuit board on a spectrum 375 plasma cutter? What is the cost of the board?
The replacement of a board is no TOO hard, just DRAW a Diagram of ALL connections when you take the "Old" one out. NEVER work on the machine live Duh, also always wait a bit to allow capacitors to discharge, or use a shorting stick, if in a hurry. Anyhow, make sure you keep all fixtures together note down all connections and label them with little stickers, With any other information on the stickers as need be. I always do this as one never remembers whats what after a bit, anyway. Just be methodical, and you will prevail.
Feb 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
The lights are working for power and gas pressure but not the DC arc....BIG Repair problem?????? It a Pak Master 25 Plasma cutter from Thermal Dynamics bought 15 years ago
Oct 30, 2009 | Welding Tools
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
If you have a old plasma cutter can you swap ot
yes it does matter.each brand is set up for their own torches.
Jul 02, 2009 | Welding Tools
Welding Tools Logo
35 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
