Canon c5185 Black text comes out blurry when printing in color. Drum is new and black looks good when just printing in black.
5 Suggested Answers
SOURCE: prints black on test page, but not when a job is sent to the printer
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Posted on Nov 19, 2007
SOURCE: Canon i960 will not print in black ink
I use a no. 4 pan head screw to drill a SMALL hole in the top of the ink cartridge, about 1/4" in back from the front edge, so you can reseal it with the screw when done.
Take a small syringe with a short needle and pull the plunger back.
Insert the needle into hole and hold cartridge in place, IN THE PRINT HEAD, while pushing the plunger down to "pressure feed" the ink into the print head.
Reseal the ink tank with the screw when done.
I think the problem stems from the new or refilled ink tank NOT making a good seal with the print head and then there is a vacuum leak at the joint.
I have done this many times with my various Canon printers with removable ink tanks and it almost invaribly works for me.
I also refil the ink tanks IN THE PRINTER rather than taking them out to help prevent the vacuum break between the print heand and the ink tank.
It also helps to use a photo printing program to "print" out a black, red, blue or yellow page (use whichever color you are having trouble with) to help start the ink flowing again as well.
It does not have to be a full 8 x 10 size, just something about 4 x 6 to help reestablish the ink flow.
Posted on Jul 17, 2008
n25an
  • 622 Answers
SOURCE: Canon IR C5185 printing black copies, would
replace the black charger... if the copies are coming out strongly black with no white lines then your drum is good... the charger died...
Posted on Dec 10, 2009
  • 3 Answers
SOURCE: canon pixma iP8500 printer will not print any black ink
Check the black cartridge and make sure the orange or yellow tape at the rear end is not still attached. If it covers the small hole on the top of the cartridge, the printer won't print black text.
Posted on Jan 27, 2013
My canon irc 5185 double image in black images. any advice
Print Black images with any color piece (ex. page with black text and one red letter in up-right corner) 40-50 pages in one job.
Are you see a double black image?
No: Fuser trouble on high-speed.
Yes: Replace the Drum Unit (Black).
Sep 10, 2013 | Canon irc5185i
My canon MP145 three-in-one printer cannot print because the coloured ink has finished. How can i continue to print using black ink only?
Hi joyce2020
Some printers do print even if one cartridge is empty.
This is what you have to do. Goto the print setting page. you will find check boxes for Print in Color OR Black& White.
Usually, the color box is checked. When you check the box for color, you can print in black and white as well provided the text is written in B&W. If you check the B&W, the printer will print everything in black including color text and graphics.
Hope this will work for you.
Good Luck
luciana44
Apr 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon IR C5185 printing black copies, would replacing black drum fix the problem?
Dec 08, 2009 | Office Equipment & Supplies
Cannot print black text
You need a new printhead, QY6-0059-000 around $40.00
Jul 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Printer will not print black ink
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Jun 25, 2007 | Canon i850 InkJet Photo Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Problems printing black
how many prints have u done with the drum, black.???, if it´s new, just clean the leeds of the black, with a piece of cloth.
Nov 14, 2006 | OKI C5100n Laser Printer
106 people viewed this question
jasbo
jasbo
