Question about Baby Gear
Is it okay to refreeze frog legs
Can you refreeze frog legs
Fish from alaska, it was frozen by the time we got it home. I was going to process it in smaller containers, but cant cut thru it. If i thaw it out some so i can cut it will it be okay to refreeze?
do not thaw and refreeze a definite no no ,use a band saw to cut it fish finger manufacturers use this system to create their products
Aug 03, 2015 | Refrigerators
Can I refreeze thawed crab legs?
It is not recommended.
Dec 29, 2014 | Refrigerators
Is it okay to refreeze meat
Depends on what temperature the meat got up to in that amount of time. If it got up past 40 degrees, I'd trash it.
Jan 05, 2014 | Computers & Internet
Is It Okay To Refreeze Meat
NO............... if you cook it first then yes
May 21, 2013 | Grilling
That handle on my bugaboo frog doesn't click into
The Cameleon, Frog and Gecko all use the same parts inside the hubs. Most common problem is the locking rods fail (little aluminum dog leg shaped thingies). The full story is in the following link complete with where to buy stainless steel replacements for $15 each. If you reuse the dome you can fix it for $30 but I recommend you replace the dome if you can source one, full story here... www.fixya.com/support/r7805199-fix_bugaboo_handle_lock
Sep 23, 2011 | Bugaboo Baby Gear
Is it okay or not... freeze meat, thaw, grind, refreeze
Yes, that would be okay. I do that all the time with my meat.
Thanks -Oscar
Mar 05, 2011 | Computers & Internet
We have a babybjorn baby carrier. Our daughter is
You may want to check that the adjustable strap at the bottom front of the carrier is at the proper position for the height and weight of your child. She shouldn't be slouching in the carrier. The carrier is designed for the legs to be slightly spread apart or 'frog legged' but she shouldn't be in a 90 degreee stradle.
Hope this is helpful.
Mar 03, 2010 | Baby Bjorn Active Baby Carrier
Need replacement clips for bugaboo frog.
contact bugaboo through their website - they'v been very helpful to me
Sep 07, 2009 | Bugaboo Frog Stroller
Baby Gear Logo
90 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
