Question about Kallista Home
Replacement parts broken tank model # P70052
Supply tub to tank
That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
My Campbell Haufield compressor does not shut off once it fills up why?
If the motor pumps the tank up to the maximum pressure then keeps on running you have a broken pressure regulator. Replace it, as over filling the tank can be extremely dangerous. The pressure regulator listed by C-H for your compressor is part number CW210100SJ and should cost you $40 to $45.
Feb 02, 2012 | Campbell Hausfeld Air Tools & Compressors
My Homelite XH2XS-0254RA Trimmer gas lines have broken off inside the gas tank, can replacement parts be obtained
Hi carlfreeland...
Yes, your fuel lines can be replaced, be sure to get the right size to fit your machine.
Go to your parts supplier with the model/serial number and manufacturer of your weedeater.
Most of the time there will be two size fuel lines, the bigger one is the one the fuel filter inside your tank is connected to.
Please take time to rate me
Jul 03, 2011 | Homelite Expand - It Brushcutter...
My flotec pressure tank seems to be waterlogged, how do I recharge it?
I don't know your model. Generally, a newer pressure tank has a flexible bladder that separates the water from the air charge. If you have water on the top of your tank, the bladder has broken. It seems that Flotec tanks have replaceable bladders. Flotec Pressure Tanks
That is a link to a company that sells parts for theses tanks.
Gary.
Dec 04, 2010 | Electrical Supplies
Fuel tank is broken. part number is required
There are probably 10 active chainsaw manufacturers today and in excess of 50 no longer in production. Each of them produce or produced 5 - 20 models. Which one of these do you need to repair/replace? A serial number is often needed to provide the required parts list.
Nov 13, 2009 | Garden
Need replacement parts
Yes, the parts are available to replace under $5.00, however a dealer will want to sell you a new tank. (this is accurate as of 2 months ago)
Feb 26, 2009 | Hoover F6021-900 Steam Vacuum
Broken water tank on steam vac duel w/rinse #f7205-910
If this is a Hoover, you can go to thehooverstore.com and order what you need. But you will need your model number. You will have to replace the tank.
Feb 21, 2008 | Vacuums
Home Logo
93 people viewed this question
Top Kallista Home Experts
Donni Steen
Tom Chichester
Are you a Kallista Home Expert? Answer questions, earn points and help others
