Ge remote how to program ge remote to control cisco dta 170hd ? do you use AUX on remote? what is code for cisco dta 170hd?
IrishDruid
  • 2712 Answers
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: i need codes for philips universal remote control
i have a sony tv and a philps universal remote control i need the code for my tv.
Posted on Mar 22, 2009
johncaman
  • 201 Answers
SOURCE: I HAVE A G.E. UNIVERSAL REMOTE CONTROL. #24912 I
Hi, try this first:
1. Manually turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the SETUP button
until the red indicator stays on, then
release the SETUP button.
3. Press and quickly release the desired
device button (TV, VCR, etc.). The
red indicator blinks off once.
4. Press the ON•OFF button
repeatedly (up to 300 times) until
the device to be controlled turns
off. The red indicator blinks off with
each button press.
Most users will store VCR codes under the VCR
button, Cable codes under CABLE, etc. If (for
example) you want to store a VCR code under
CABLE, first follow the procedure for Direct Code
Entry (previous page) and press CABLE in step 2
of Direct Code Entry, then enter ANY VCR code in
step 3 of Direct Code Entry. Then follow the steps
above for Code Search.
Note: Code Search starts from the currently
stored four digit number under that mode.
Sometimes the first code that “works” with your
device may only allow limited functionality (e.g.
the MENU button might not work). There may be
a code that performs more functions. Continue the
code search process until the best code is found.
5. Press and release ENTER to install the code.
Otherwise, you'll have to do manual code entry, here are the possible Emerson codes:
EMERSON ................ 0004 0009 0044
................. 0135 0049 0051 0189 0053
................. 0147 0039 0130 0227 0233
....... 0250 0252 0254 0257 0265 0266
....... 0310 0325 0456 0040 0041 0042
....... 0021 0023 0024 0179 0045 0025
....... 0027 0030 0032 0034 0035 0037
Here's the manual code entry instructions:
1. Press and hold the SETUP button until
the red indicator stays on, then release
the SETUP button.
2. Press and release the desired device
button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
3. Enter the 4 digit code
from the code tables
(on separate sheet).
Note: after a valid
code entry, the red
indicator turns off. For
an invalid code, the
red indicator flashes.
4. With your device on, press ON•OFF.
If the device turns off, no further
programming is required. Note: If
some buttons do not operate your
equipment, try one of the other
Hope this helps, please rate :)
MNfisherman
  • 11896 Answers
SOURCE: i lost the programing codes for my remote control
www.jascoproducts.com/support/universal-remote-codes.asp
www.xdiv.com/remotes/
www.remotecentral.com/features/remotes.htm
www.tvcodes.com
www.remote-codes.com/
copy and paste any one of these links in your address bar to get your codes
Posted on Sep 26, 2009
  • 5 Answers
SOURCE: Comcast DTA code for my HTR-D11 Haier Remote
<a heref="http://universalremotecodes.blogspot.com/">Magnavox Universal Remote</a> CHECK remote codes here!
Posted on Jul 18, 2010
Orion model 1331 user guide
Sue, cross referenced your remote to a Cisco remote, manual link below. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.cisco.com/c/dam/en/us/td/docs/video/at_home/Set-Tops/DTA/4030042_B.pdf
http://www.orion.newremotecontrol.com/OrionTV.php
Welcome to Remote Central Universal Remote Control Reviews More
How to Program Universal Remote
Codes for Universal Remotes
Apr 10, 2016 | Orion Televison & Video
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
Need code for my RCA universal remote to program Cisco dta 170hd cable box?
0149, 0125, 0193. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Dec 12, 2015 | RCA Televison & Video
Use Universal Remote on DTA
I needed to setup my Vizio TV's remote to control the Cisco DTA 170HD. I was able to get it working by using the Scientific Atlanta code 01877. Follow this link to read the user manual for the Vizio and there are more codes posted in there.
http://store.vizio.com/documents/downloads/hdtv/VU42LF/Manual.pdf
Nov 24, 2013 | Televison & Video
Need code
I HOPE THIS HELPS... YOU DIDN'T GIVE US MUCH TO GO ON....
BEST WISHES!
GE Universal remote controls - instructionsHow to Program a GE Universal Remote Control
Programming a GE/Jasco Universal Remote Control is simple, requires only a few simple steps. You need to know the code of device you are programming into the remote. See the GE remote control codes page for3 digit or 4 digit GE remotes.
How to enter codes manually:
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
The SLEEP feature
Some GE remote controls like the RM94902, RM94904 or RM94905 have a handy "sleep feature" enabling you to turn off your TV after a preprogrammed time interval of 1 to 99 minutes. To use the sleep feature follow these steps:
1: Press and hold the "SLEEP" button until the indicator light turns on.
2: Enter the time interval in minutes using the numerical keypad. (for minutes from 1 to 9 press 0 before the actual number).
3: Leave the remote aimed at the television set.
To turn off the sleep feature, press and hold "SLEEP" until the indicator light blinks or press the "POWER" button to turn off the TV.
http://www.eliztech.com/remotes/ge-howto.php
Oct 16, 2012 | Televison & Video
Looking the CISCO DTA50 code for GE Universal Remote Control
There is no setup codes for this device to any model GE remotes.
Sep 01, 2012 | Universal Remote Control GE174Universal...
Program remote to tv
Here are the codes for your GE TV: 645, 742, 763, 531, 676, or 690.I have provided the instructions to program the DISH remote to your GE TV:AddressRemote to TV
  1. While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
  2. Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
Ifyou are programming a code into AUX Mode, you must do the following beforeentering the device code:Press 0 for a TV (if TV code is 500, enter 0500)Press 1 for a VCR/DVD (if DVD code is 617,enter 1617) Press 2 for any other device (if device codeis 639, enter 2639)
  1. Press the Pound (#) button - The mode button you are programming should flash three times
  2. Press the large, red POWER button - The device should turn off
Jan 09, 2012 | GE 24993 Remote Control
My olevia tv and Ge Remote control wont work lost code. Help?
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
LIGHT lights, then release.
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
Feb 01, 2010 | GE JASRM24912 Remote Control
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
Electro Med Services...
