Question about Refrigerators
Sub zero model 241RFD
FRIDGE WORKS FINE. BOTTOM FREEZER DOES NOT FREEZE
  • 178 Answers
SOURCE: Sub-Zero model 211
First of all, the freezer temperature is the MAIN part of the unit. Either look for a new thermostat for your model unit and try switching it out, or look for a new fan motor for the freezer. The concept of the refrigerator is just like an A/C unit. It is designed to remove heat from one spot and andcarry it to a discharge place of NO imporatnce. I would definately start with the thermostat in the top of your refrigerator since it is likely the least expensive solution. Research your particular model number for proper fan replacement if it comes down to it. Also, check to insure that the freezer isn't frozen up behind the back wall. Let me know if there is anything else I can help with or if you need more assistance on the same issue.
Posted on Mar 14, 2008
SOURCE: sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Posted on Oct 08, 2008
  • 1810 Answers
SOURCE: 1983 sub zero 241rfd with extensive ice on fridge
sounds like a thermostat and a timer to me
start off with a thermostat if that doesnt work buy a timer
it's a bit expensive like 100.00 buy if you like the fridge or cant afford a new 1
thermo $10- $30
timer 30-70 try to buy recycled parts that are tested there cheeper
Posted on Jul 27, 2009
  • 2468 Answers
SOURCE: older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Posted on Jan 17, 2010
heatman101
  • 43501 Answers
SOURCE: fridge does not stay cold but the freezer works
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 19, 2010
Kitchen aid bottom freezer fridge. The freezer part is cool but does not freeze.
Maybe lossing gas slowly have your tech confirm this for you.
Jan 14, 2016 | Refrigerators
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
LG Fridge bottom freezer
Have you had the evap fan replaced, if not that sounds like your issue.
Nov 06, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
