Toshiba satellite m40
Can u get 1bt for it and whats the hard drive type
  • 32,281 Answers
The model Toshiba laptop came installed with a 80Gb hard drive and can support a hard drive up to a max. 120Gb.
If you want a larger hard drive you will need to use an external USB hard drive.
Posted on May 06, 2013
3 Suggested Answers
Tabani
  • 129 Answers
SOURCE: how many hard drives does my toshiba satellite
Dear sir, I believe one hard drive, as every laptop contains one hard drive. You might have several partitions/drives like C:, D:, E: and F:. All of these drives are part of your Hard Disk.
Thank you
Regards Fahad
Posted on Jan 24, 2010
nblady
  • 206 Answers
SOURCE: How do I remove my hard drive from my Toshiba Satellite R15-S829?
READ THIS ALL THE WAY THROUGH. REMOVE THE BATTERY AND POWER BEFORE ANY WORK IS DONE. HAVE ALREADY BACKED UP ALL YOUR DATA.
Toshiba Support Site warns not to try this at home.
User's Manual does not list HD removal.
That being said.....
this is the instructions for a P15-S479, but may be what you need.
Instructions:
The hard drive is located under the CD/DVD drive. Before you start taking apart the laptop, remove the battery and unplug the AC power.
1. You have to remove the CD/DVD drive. Turn the laptop over. Remove one screw right above the dive and slide the drive out of the laptop.
2. When the CD/DVD drive is removed, you’ll see a metal plate. The metal plate is secured by 4 screws. Remove them and lift up the plate from the bay. The hard drive is located right under the plate.
3. After you remove the plate, you’ll see the hard drive. The hard drive also secured by 4 screws. Remove the screws, slide the hard dire to disconnect it from the connector on the moterboard and lift it up.
4. You have to transfer the brackets from the old hard drive to a new hard drive. Also, if there is a foil shielding around the old hard drive, you’ll have to transfer it to a new hard drive too.
Here’s a disassembly guide with pictures: Toshiba Satellite P10/P15 laptops. How to remove the hard drive.
Remember the precautions and warranty information from Toshiba before you start. Try to have someone who is really into laptops before you begin
Good luck
ps: Other laptops have their HD's under the keyboard, or in a removable door on the bottom.
Posted on Feb 15, 2010
TOSHIBA Satellite 1115-S103 hard drive upgrade?
I was unable to find the specific laptop
Toshiba Satellite hard drive removal
http://www.youtube.com/watch?v=8xv9oiNxyZk
How to replace the hard drive on a Toshiba laptop
Hope this helps.
Nov 26, 2012 | Toshiba Satellite 1115-S103 Notebook
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
          The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
          An alternative -
          You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
          The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
          Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
          What type of hard drive do i purchase for my toshiba satellite A135-S4656? when i start up my laptop it says replace the hard drive. But I'm not sure what model to replace it with? Can you help me out? ...
          160GB SATA 2.5 inch. You can go larger (320-500GB).
          You do realize that after replacing the hard drive, all of your data and windows operating system will be on the old disk.
          May 21, 2010 | Toshiba Satellite A135 Notebook
          What is the drive type used in the Toshiba 2415 S205 laptop?
          Specifications of TOSHIBA Satellite? 2415 Series
          P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Home
          Satellite 2415-S206
          P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Pro
          Performance
          Mobile Intel® Pentium® 4 processor-M at 2.00GHz
          Memmory 256MB expandable to 1024MB
          All-in-one design
          40GB* hard disk drive
          DVD-ROM/CDRW multi-function drive
          Mar 15, 2010 | Toshiba Satellite 2415-S205 Notebook
          I need a hard drive for my Toshiba Satellite M55-s135. What should i buy and how do i buy it?
          The type of drive you need is an IDE drive. You can buy a new a new drive online through places like www.tigerdirect.com or www.bestbuy.com or in a store such as Best Buy or even Office Depot.
          Please make sure you buy a laptop IDE hard drive...all others will NOT work.
          Dec 23, 2009 | Toshiba Satellite M55-S135 Notebook
          Internal Hard Disk Upgrade
          Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
          Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
          Hard drive and memory
          the laptop should pick up a 20gb or 60gb ide hard drive with no problem
          Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
          Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
          Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          Computers & Internet Logo
          24 people viewed this question
          David Payne
          David Payne
