Hi I have a lg washer dryer wd-1247rd I have cleaned everything I could washed the waste water hose out with hose filter is clean heaps of stuff came out . But when on a cycle it cuts out when about to rinse and a message comes OE wich states in the book that hose is kinked
blueextc3221
  • 15935 Answers
SOURCE: my lg front load washer stops and give me an error message OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
  • 383 Answers
SOURCE: OE problem with the LG WD - 12270BD Washer
Turn the knob to start and restart again let it run thru the course.
AND IF THIS DONT WORK TRY THIS:
Put knob on spin and let it run thru the course.
Posted on Nov 26, 2007
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
  • 3 Answers
SOURCE: My front loading LG 1814CW goes through the wash cycle but after
Take the drain filter out and look behind it with a flashlight. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Posted on Mar 25, 2009
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
IE error on wd1484adp
LG's 'IE' stands for '(water) Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB
Jun 15, 2012 | LG Wd-1484adp 8/4kg White Direct Drive...
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
May 26, 2011 | LG WD-3245 Front Load Washer / Dryer
THE WASHER DOES NOT COMPLEAT THE CYCLE IT STOPS AND Codes IE
Are all taps turned on, is the filters in the hose connections clean? The code means it is not getting water, if water supply is ok one of the valves may be faulty.
Apr 18, 2010 | LG WD-3274RHD Front Load Washer / Dryer
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
How do we clean the dryer 's filter?
I think I know what you mean - the machine itself does not have a lint filter and over time I've noted that it can build up around the large rubber door gasket. You will simply need to be more fastidious about cleaning it out after each cycle. I've had success using an old toothbrush dunked in some water to get the stuff out. The washer's filter (located in the lower left corner of the machine) only traps large solid debris. Hope that helps!
Jun 26, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LG Washer/Dryer won't drain
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Washer/Dryer
weak pump...but remember in the drying cycle water is ment to come in and flush out lint and produce air flow for drying..it also cools drum..
Dec 16, 2008 | LG WD-14124RD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
