Crazy fast speed on my Dual 714 Q turntable
Just got it given to me and the plater spins out of control fast. the pitch control makes no difference.
  • mar010282
    mar010282 Dec 08, 2013
    definately not the problem. If that were the problem the platter would eventually spin at a constant speed. Mine keeps rotating so fast that the needle just slides across the record. it starts at a normal speed and just keeps going faster and faster until the writing on the records is just a colored line. must be a servo problem i think. But i'm no electrcian.
  • Audio Service Clinic Dec 08, 2013
    My appologies. You have a Direct Drive turntable. They use a circuit known as a Phase Locked Loop, which attempts to lock the speed. Could be one of the components in that circuit. Unfortunately, the Direct Drive motor itself contains all the speed circuitry and is generally considered a non repairable component. The entire motor is replaced as a unit. That's not to say that it couldn't be repaired, but it is generally not. You might try to clean the pich controls with LPS 2, as they are part of this circuit and if they get noisey(dirty) they can effect this circuit as well. If you need anything else, please contact me at my website, audioserviceclinic.com. Thank you.
  • 15,950 Answers
Posted on May 12, 2013
Testimonial: "Thanks for the link, but it has no trouble shooting for my problem. maybe if i open it up i can see the exact problem. The manual did give me a good overview of how to locate the areas that the problem may occur but no definitive answers. Thanks again!!"
    You have a belt driven turntable. If you look at the motor pulley, you'll see that it has an upper and lower guide. That is where the belt is supposed to ride. My guess is that the belt is about have way over the top ridge. Move the belt down and rotate the patter by hand a few times, to be sure the belt stays where it belongs. For more information, please visit my website at audioserviceclinic.com. Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
Audio Service Clinic You have a belt driven turntable. If you look at the motor pulley, you'll see that it has an upper and lower guide. That is where the belt is supposed to ride. My guess is that the belt is about have way over the top ridge. Move the belt down and rotate the patter by hand a few times, to be sure the belt stays where it belongs. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 08, 2013
How do I adjust the pitch / rotation speed for the turntable of my Emerson NR305TT ?
If the pitch is adjustable then there will be a little round knob to adjust it near the pivot of the turntable tonearm. If not the pitch is not adjustable.
Jun 23, 2016 | Emerson Nr305tt Heritage Home Audio System...
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
My deck plays too fast and i must adjust pitch control to -2.5 to get the speed correct... is there a way to adjust speed internally?
this is calibrated from factory, the control board is faling check for any pot. If available, adjust a little the speed pot
Jan 08, 2010 | Stanton STR8-50 Turntable
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Oct 22, 2009 | Stanton T.50 Turntable
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Technics Turntables
Sounds like you need a new pitch control. YOu can purchase a pitch control separately and install yourself, however soldering is required. You will have to solder off the old board, and solder on the new board.
You can purchase the PART HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 16, 2008 | Technics SL-1200MK2 Turntable
356 people viewed this question
 Grubhead
Grubhead
