Samsung washer sensorquick P801 won't turn on. A
4 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Ice maker wont work after water turned off then back on in few da
it's common for the icemaker fill tube to freeze up when water pressure is lost such as when water is turned off for a long period of time. the fill tube is the piece that comes into the back of the icemaker from the rear of the refrig. what i do is heat the tube up with a hair dryer and melt the ice out. message back if you have any other problems or questions thanks peyton..
Posted on Feb 22, 2009
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
  • 229 Answers
SOURCE: my samsung gt 15500 won't
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
Posted on May 12, 2011
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
My 1996 has no spark and won't go into gear. when key is turned to on position it stuck in park. Car just turns over won't start either.
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????6
Jul 28, 2011 | 1996 Pontiac Grand Am
I just got my laptopm about 4 - 5 days ago . It's
Seeing that that computer is only 4 to 5 days old the best advise i can give you is contact Dell Support or take it back to the store you bought it at and get it replaced.
Jul 10, 2011 | Dell Computers & Internet
My Samsung focus won't let me download free apps. it keeps telling me "can't get this info right now check back in a little while." its been doing it since I got it. which was Monday.
Hey,
There are several fixes you can try: 1) Turn the Wi-Fi on if it isn't already. If it is, try turning it on and then wait a few minutes before turning it back on.
2) Go to the Settings menu and tap on Email and Account. Then go to Windows Live. Remove your password and enter it again.
3) You can also try changing your Windows Live password from www.account.live.com, and then enter it again on the phone.
If none of these work, then it's possible that it might be a problem on Samsung's end, and they might have server problems.
Let me know if any of these solutions work or not. Thanks, virjog
May 07, 2011 | Samsung Focus i917 (8 GB) Smartphone
Samsung sensor quick P801 can't close the door. The main front door can not be close easily. I take me 6 to 7 try to close it. Sometime I need to slap the door firmly. The Door seem to be close but just...
you should not be able to open or close the door with the washer ON. You must first shut off machine before closing the door, then turn the machine ON, this should lock the door closed. to open the door, you must shut the machine OFF, then the door should open easily. Follow the directions in the manual... you can Download the owners manual here, in your language of choice; Follow the link below. just copy and paste it into you browsers window.
http://www.usersmanualguide.com/samsung/washing_machine__drum_type/p801
Don't forget to rate the answer.
Jan 24, 2011 | Samsung Washing Machines
Fabric softener does not drain out but remains in the tray. Tray fills with water and stays there. I have cleaned drain hole at tha bottom with pipe cleaners and it is clear! This is on a front loas...
I'm having the same problem with the fabric softener dispenser not emptying and filling with water. I, too, have cleaned everything out and there are no clogs. What's the solution?
Dec 29, 2009 | Samsung WF203ANW Front Load Washer
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
