Question about Kohler Home
Motor on but jets only work sometimes
Pressing the knob always turns motor on but not always jets work. Suggestions? Thank you
  • Kohler Master
  • 717 Answers
Need more information about what kind of control you are using to turn the tub on/off.
does it turn off when you can get it turned on?
Rod
US Parts Center
888-521-6183
Posted on May 10, 2013
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
Nov 17, 2016 | Washing Machines
Front wipers will not shut off
No matter what you have done, the fact remains that the motor is still receiving power!!!!!! And if those are the only two items in the path of power transmission to the motor, then one/both has to be fubar.
And until you locate the issue, you can always throw in a toggle switch on the ground line to turn on/off.
Feb 18, 2016 | Jet 2001 Dodge Dakota - 3.9L V6 -...
I have a Neptune air tub and the motor turns on when I press on but the air is not coming out of the jets. The tub does not have an air knob
So you can hear the air blower turn on however there are no little bubbles coming out of the air injectors...
I would have you verify that the blower is blowing air out. Either the hose has come off and it is blowing air under the tub or the fan has disengaged itself from the motor and is not turning.
I will ask you to verify that one of those two things has happened or possibly the check valve in your system is closed and will not open.
US Parts Center
Nov 10, 2013 | Neptune DB60TAM Whirlpools and Air Tubs
F21 what can I do? Please please
Hi
F21 error in your Bosch washer relates to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Bosch Logixx WAS2446 Front Load Washer
Washer wont spin & drain all the time...
sounds to me like you need to replace the timer if you can get it to work by clicking the knob sometimes. i have had washers that have had that oil smell too but it was on an older unit and the motor was actually slinging oil onto the floor. you may have two unrelated issues.
Nov 06, 2009 | Washing Machines
Jetted bath tub has stopped working - motor hums, will not run
The shaft on the motor should spin freely as should the impeller when attached to the pump. If there is drag on either, replace the pump and motor assembly. I have worked on jetted tubs for the past 5 years, I have seen seized pumps more than once.
Mar 06, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Feb 11, 2009 | Home
Drum will not turn
From your description, you may have a bad spot in the armature of the motor, or a faulty centrifugal switch on the motor.
May 24, 2008 | Dryers
Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
Oct 24, 2007 | Ovens
Home Logo
66 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
