Question about 2011-2013 Hyundai Elantra CalTrend Dura-Plus Seat Covers HY121-06DD - Canvas
Navione exe hello my dear! Iam from iran!I am need a iran map for my davaise! Please help me?! Thank you very much
I have an aftermarket radio/navigation system in my truck. when I hit the navigation button it is looking for the following. \storage card\navione\navione.exe,check sd card. my card is blank
You have a defective NAV system, pull it out and send it in for repair or.... Just use your cell phone's Google maps app for navigation, it is far better then any car nav system.
Aug 11, 2016 | 2014 Ford F-150
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Will the hds7 gen 2 read navionics lake map?
Yes, all Lowrance products will use and display Navionics map data.
Compatibility Guide America
Here is a link to the navionics compatability page so you can see which map cards will work in your unit.
Feb 03, 2015 | Lowrance HDS7 GEN2 Insight 83/200KHZ
Mitsubishi vacuum diagram
hello
please answer me to khalajy2@yahoo.com
i have mitsubishi lancer with 4G13 motor and sndlw body (1992 year)
the carburator is single(is not electrical) the all hoses are moved and i dont now how to fixe them please help me for a plan or map of hoses of carburator(i am teacher in iran i can buy a lancer 1992 after 29 year teaching do you beleave this this is iran)
thanks
Aug 04, 2012 | Mitsubishi Cars & Trucks
Program:naviOne.exe Exception: 0xC0000005 Address:0128735C
Hi ,
You need to donwload the software from the bellow mentioned link:
http://software.informer.com/getfree-navione.exe-gps/
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 25, 2010 | GPS
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have...
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Apr 22, 2009 | GPS
Navionics gold card & humminbird 78c2
Hi!
You NEED to have a gps lock in order for the card to show it's true potential.
Also check in the menu for a setting that says "Map detail" and change it to all available. It could be the setting is on a lesser choice (like the internal mapping and not the new sd card)
Hope this helps!
Mike
Aug 06, 2008 | Navionics: Gold+ Chart Cartridge
2011-2013 Hyundai Elantra CalTrend Dura-Plus Seat Covers HY121-06DD - Canvas Logo
35 people viewed this question
Top CalTrend Auto Accessories Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CalTrend Auto Accessories Vehicle Part and Accessory Expert? Answer questions, earn points and help others
