Question about Fujitsu Computers & Internet
FUJITSU LIFEBOOK AH530 SUDDENLY SHUT DOWN
LIFEBOOK AH530 SUDDDENLY SHUT DOWN AND NOW POWER SWITCH DOES NOT TURN T ON AND I CANNOT GET IT TO TURN BACK ON. WHAT DO I DO?
SOURCE: Fujitsu LIFEBOOK C1020 power problem
or a bfoken powr jack.I replaced mine recently for £4.00 and took approx 2 hours.
Posted on Aug 17, 2008
shibuda
  • 1812 Answers
SOURCE: MY fujitsu lifebook ah530 keeps
Your display setting does not match.You need to setting the display right way.Or you uninstall and install the VGA (graphics)driver again,and simply restart the PC.
Hope it will solve your problem .
Posted on Dec 17, 2010
jcrowder0846
  • 470 Answers
SOURCE: how to connect bluetooth device on LIFEBOOK AH530
You are going to have to pair your device with your computer. Open the PC Bluetooth manager. Select seek all devices when connected. Make sure to check that option. Turn on your device making sure that it is also set to seek a connection once PC has found the device. The software will open a window that will give you paring code make sure that you type the code into the box it has to be perfectly done. Then the devices can be paired up. To see if you located your Bluetooth device go to devices you should see your device there. If not click on add new device make sure your device is turned on again able to seek. It will connect to the PC.
John
Posted on Apr 21, 2012
joelwilcox
  • 1274 Answers
SOURCE: The internal microphone is missing from my Fujitsu AH530. Is there one?
yes there should be an internal microphone, what do you mean it's missing?
Posted on Apr 27, 2012
SOURCE: Built-In Microphone Doesn't Work.
microphone or wi-fi
Posted on Aug 24, 2012
My fujitsu lifebook ah530 screen blinks constantly plz help
Set the screen-resolution to 640-by-480, to see if the blinking stops.
If it does, set the screen-resolution to 800-by-600, to see if it this higher resolution is supported. Also, try 1024-by-768.
May 16, 2014 | Fujitsu LifeBook AH530 NoteBook
Where is the inverter for fujitsu lifebook ah530
lcd inverter are commonly found at the bottom of the LCD screen after you'd remove the edges cover. try to remove the VGA cable from the laptop and see if the screen will blink or flash.
thanks
Apr 01, 2014 | Fujitsu LifeBook AH530 NoteBook
Fujitsu LifeBook AH530 NoteBook turns itself off
Clean the fan and airways. It is probably overheating.
Nov 11, 2013 | Fujitsu LifeBook AH530 NoteBook
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
How to turn on my wireless
Try looking for a toggle switch on the laptop itself, if not go to
Network and Sharing Center > Change Adapter Settings
and right-click your wireless device and select Enable.
Jun 18, 2012 | Fujitsu LifeBook AH530 NoteBook
How to connect bluetooth device on LIFEBOOK AH530
John
Apr 20, 2012 | Fujitsu LIFEBOOK AH530 NOTEBOOK (FPCR33681
I forget BIOS password for my fujitsu lifebook a sereise laptop how can i solve this problem
1. Turn off the laptop2. Remove the power cord3. Remove the battery4. Dismantle back screws and pop open the cover.5. Locate the Dry cell (Button Cell)6. Remove the button cell from the laptop.7. Wait for 10 Seconds8. Put back the button cell.9. Fix the back cover by re-screwing10. Put back your laptop battery11. Turn on the laptop12. Thats it !
Jul 18, 2011 | Fujitsu LifeBook AH530 NoteBook
Computers & Internet Logo
43 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
