Question about Electrical Supplies
Wiring diagram for honda northstar 5500 IPG
No continuity on my GFI circuitry
Hello,I have a 1973 honda st-90 trail bike.My problem is that the bike came with no main wireing harness or circuitry only a coil and the leads from the points and stator.Is there a way to wire the the...
Hi, Riley the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1973 honda st 90 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda S90 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
1973 Honda ST90 Owner Manual
Jul 29, 2017 | Honda Motorcycles
Northstar 5500. Voltage good. sounds and runs good. But, makes bad noise from gen head area when under any load. I replaced the bearing. Anything else?
Stator is contacting the rotor, did you replace both bearings? remove the stator and look for damage on the stator and rotor laminates
Feb 26, 2015 | Northstar 5500/4500 Watt CARB Compliant...
2005 Honda Activa wiring diagram
Hi, Anonymous first check for continuity at the power and ground wire at the horn, then check for continuity at the horn button, back in the day there was a small adjustment screw on the back of the horn, by turning it one way or the other you could set the limit on how much the diaphragm vibrated.
2005 Honda Activa wiring diagram Google Search
Honda Activa Scooter Horn not working
Learning to repair the horn of Two Wheeler Hindi
Honda Activa 2011
Sep 18, 2014 | 2005 Honda Activa
Wiring diagram for Heartland 2013 Key Largo
Wiring diagrams are not available as the manufacturers to not publish them. You have to determine which circuit the outlets are on and then from there determine the outlet prior to the failed outlet and trace back from there until you identify the point of failure. Most trailers are wired with GFI outlets with the primary GFI being in the bathroom or the kitchen and all outlets wired after that point are controlled by that one primary. If you do not have power go to the primary and press the reset button.
Feb 19, 2014 | Heartland 2013 Landmark LM Key Largo
How to flash field north star 5500 generator
wire a 120v 15a to 9vdc or 12vdc battery make sure you have no voltage out of the 240 side. with the unit running plug into the 120v receptacl QUICKLY pull out. check power out put. if it did'nt work check your battery, than do it again twice as long. you must check all component before doing this to make sure you don't have any other fail-er. this is danger-us be careful. good luck
Oct 08, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Diagram of cadilac northstar engine exploded view of a cadilac northstar engine
need 1998 northstar engine diagram to change the head gasket thanks
Sep 30, 2009 | 2001 Cadillac DeVille
Honda 5500 Generator
If you have checked the stator, rotor and brushes and they appear alright then it is probably a voltage regulator. The honda dealer can run a test and confirm the problem at very little expense. It cost me 25 dollars Canadian to preform the test and it was well worth the money because you cannot return electrical parts and they can be very expensive. Have a great day!
davedulmage@sympatico.ca
Aug 13, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Low output from NorthStar 5500PPG
There are a few scenarios that can cause this.
1) The extension cord that you are using is too long / too light of a guage. Try a heavier extension cord, or plug directly into the generator.
2) The alternator has lost its "residual magnetism" and may need to be reflashed. Consult Northstar for instructions and details.
3) The voltage regulator (actually a simple capacitor) may be "weak"
4) The diode for field winding may be bad.
You can get a copy of your manual here, page 40 has diagram and part numbers.
http://www.northerntool.com/downloads/manuals/165911.pdf?cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=http%3A%2F%2Fwww.google.com%2F%26
Apr 02, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Electrical Supplies Logo
65 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
