Question about Dell Inspiron 710m Notebook
No laptop screen.
When i turn on my laptop, there is no picture. The screen turns on, but the actuall screen itself is blank and white. I have tried turning it on and off but nothing works. The fan runs but there is no screen. Help.
  • 10 more comments
  • Anonymous Nov 09, 2007
    my computer boots,but then gives a message that reads as follows:a disc read error occured.press control,alt and delete to restart when i do that it gives me the same message
  • lal anar Nov 17, 2007
    I have same problem with my Toshiba Tecra A3-S611. Its two years old.
    Never gave me any problem, one night it froze. I clicked shut down or
    re-start from Windows, did not do anything. Power light on, Fan works,
    CD rom spins, HDD light on, but SCREEN remains BLACK. No red TOSHIBA
    screen came up before loading windows. I manually turned power on and
    off several times before it loads or boot to windows. Sometimes I spend
    over 45 minutes turning power on and off praying it boots and load
    windows. Now I keep it on Standby mode at least it wont bother me. But
    I can not install my wireles card or any other software because it asks
    to restart the system. Is this bad mobo or is it a software related
    issue ?
  • Sonkin Dec 01, 2007
    I noticed my screen is working but is dark, if i really try i can see windows and objects on the screen but it is dark..
  • Anonymous Dec 11, 2007
    screen is blank needs rebooting
  • Anonymous Dec 15, 2007
    I HAVE CHECKED RAM
  • Anonymous Dec 20, 2007
    I have a Dell Inspiron/8000. When I turn the system on, the screen appears only for a couple of seconds and then goes blank. The computer itself works, because I hooked another screen to the laptop and that screen works, however the laptop screen itself is still blank. I turned the unit off and restarted it several times, but with no luck. Please help!
  • fitzbar Dec 31, 2007
    I also get a blank screen on my Gateway Profile 4 (thought itwas 3, does it make a difference?)and have to restart over and over again and finally when it starts put it in safe mode with networking. I was told that the problem is with the graphics driver and I could fix it in the device manager--where is that??? Is that the add/remove??? Then if I uninstall the NVDIV which is the only thing I see there how will I be able to see when I need to do the next thing and where is the place to find it? The Gateway place doesn't show me anything.
  • xaxa Jan 07, 2008
    When i turn on my laptop Inspiron 6400, "Window XP" loading picture is appeared. But after this there is no standard "window picture" with icons and so on. The screen turns on, but the actuall screen itself is black. I connected the external screen. There is no any signal from PC but screen is ready for operation. The Fn+F8 combination switch ext and int screen but both are black.
    I would like save my information from HD
    Help
    [email protected]
  • Anonymous Jan 13, 2008
    I have a gateway MX6920 and when I turn it on nothing appears on the screen, the screen lights up, the HDD light lights up but no display.
  • agassi8219 Apr 25, 2008
    hp compaq nc6000 turns on sometimes normally. and sometimes it turns on but shows only black screen and turns off after few seconds. but when it turns on normally and goes to microsoft windows xp. it freezes or shuts down suddently. i disassembled the laptop into pieces and pulled the cpu and reback in with the fan . still same problem. what do i do
  • fadel2006 Jul 14, 2008
    I HAVE ASONY PCG-TR1 WHEN I TERN IT ON LIGHT BUT NOT OPEN AND BLACK SCREEN
  • Anonymous Nov 12, 2008
    I have the blank screen problem too for HP dv9500. blank screen on startup. right before this was happening the screen would pixelate in bizarre colors.
  • 3 Answers
Forgat my password for my computer what should i do
Posted on Jul 27, 2010
This might be your conector from the screen to motherboard.if you carefully press down on the key board in the area around f6 keys -f11 keys and number 6 key to + keys.it may be enough to get the screen connctor down.But be careful.If you are brave enough you may lift bezzle and remove keyboard and de-tatch the screen connector c;ean motherboard connector and re-atatch carefully
Posted on Dec 03, 2007
Benimur
You are a savior. you just saved 200-300 CHF. I just swapt RAMS...that;s all...My notebook is working like new.
Posted on Jan 16, 2008
One other thing mate,
If you have an external video output on the back of the laptop, hook up a monitor to it and see if you get a normal screen on that. If so, you may have a bad lcd display...
fooled me more than once on that...
Posted on Oct 15, 2007
The upper idea helped!!!
I had the same problem on my laptop, opened the memory box, took it out and reinstalled it, and it is completely ok.
Thanks very much.
Ziggy
Posted on Oct 12, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description and assuming there is sufficient power to the unit, I would think that it is not a display problem but rather the motherboard is not booting. Since it is very likely that the video shares memory, it may be memory problem. You have to turn your laptop upsidedown and look for the panel/latch/cover of the memory. There might be a small screw or two that you have to remove before being able to flip it open. Inside would be 1 or 2 memories, try wiggling them a bit, remove/reinsert, clean the prongs/pins or simple reseat them. Normally there are two locks on both sides of the memory that keeps it inplace. On the other hand, to verify that your motherboard is booting even without a display, boot normally even if you can't see anything, wait a minute or so to let things run as they should, the numberlock and capslock should work even without a display if your MB booted just fine, if not then it is the MB and you may need the services of a qualified professional to have it fix. Hopes this gives you an idea. Good luck and pls post again how things turnup. Kind regards.
Posted on Aug 10, 2007
4 Suggested Answers
SOURCE:
  • 3940 Answers
SOURCE: Inspiron 6400 doesn't start.
On Flash Flash indicates that no RAM memory is being detected. So remove both RAM modules, insert 1 at a 30 deg angle till the gold contacts cannot be seen, then lock it in place, and see if the RAM is detected. Test both modules in both slots, see if system will boot with at least one. If no change, try a new RAM module, if still no change, replace the motherboard
Posted on Jul 05, 2009
kamal1984
  • 1383 Answers
SOURCE: laptop turns on no picture on screen.
when you power up the computer press F8 key then if you cna see safe mode and other menu then your computer is ok only screen resolution issue for that enter in enable vga mode.
then go to control panel and then dispaly then settings then changfe screen resolution to 1024*768
then if you can't see safe mode and other menu then you have reset your bios
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 16, 2009
  • 28 Answers
SOURCE: Computer fan is loud & computer running slow
There are a number of reasons might be affecting, some are dangerous while others not that serious. Learn why and how you can speed it up easily from: http://www.whyismypcsoslow.net/ hope this helps take your stress out!
Posted on Sep 02, 2012
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
There is a white blank screen when i turn on
A white blank screen usually means that there is no data reaching the LCD. This can be caused by a bad video card, bad cable, or bad LCD. Rarely, the cable is just unplugged on either the back of the LCD or on the system board (or video card if separate).
Apr 25, 2010 | Computers & Internet
Sony Vaio faulty screen?
First, lets make sure that the screen is actually blank or very very dim. Look very closely at the screen and try to see an outline or shadow or anything that might give an indication that the desktop is actually up and running. There is the possiblity that just the backlight is off and the screen is actually working. Try taking a flashlight and shine it at the bottom of the screen and try to illuminate the bottom pointing upwards try to illuminate the screen. If you can see anything on the screen then most likely the inverter has failed and can be replaced by removing the screen bezel, unplugging two connections and replacing the inverter which is secure under the lcd screen itself. The inverter costs approx. 20 bucks.
If you do not see anything, then you need to check the vga port on the laptop. this port allows you to attach an external monitor to the laptop and transfer the image to an external monitor. This will tell us if whether your motherboard has fried out the video card. If you do get a picture on an external monitor, then perhaps the only issue is a failed screen.
Dec 08, 2009 | Office Equipment & Supplies
MY LAPTOP TURN ON YOU HEAR THE LOGO SOUND,SCREEN TURN WHITE,HARD DRIVE KEEP TURNNING ON AND OFF BUT NO PICTURE,JUST A BLANK WHITE SCREEN. I HAVE A SONY VIAO PCG-Z1VA MODEL.
Insert your Windows installation disk and select Repair Windows rather than Install. Hopefully it will allow you to boot properly.
Sep 23, 2009 | Dell Inspiron 6000 Notebook
Screen not working
Lisa-
I am sorry to hear that the new sidekick 3 is not working for your son.
Is the screen white, blank, or just hard to see?
If white, then the flex cable needs to be reseated.
How to fix a blank white Screen on a Sidekick
If dark blank, then reseat the lcd assy itself and see if it works
Reseat the Sidekick 3 LCD Screen
If hard to see the screen, then the backlight is dead. A new screen is needed for that.
Replace the Sidekick 3 LCD Screen
I hope that helps
Feel free to contact me if you have questions
Dec 15, 2008 | T-Mobile Sidekick II
Blank screen
can you obtain a linux dsl stick / cd - This will help bypass your HD
Do you have floppy drive - if so..can you create a DOS boot disk
try and boot from another media - this will rule out Hard drive / os failure, and focus on the laptop itself.
If this fails - it would appear to be the video driver... let me know from here on..
Aug 06, 2008 | Acer Aspire 3690-2196 Notebook
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Today, as i was using my laptop (Acer Aspire 7000), all of a sudden the screen turned almost translucent with white horizontal lines (probably 0.5mm in width). The actual laptop itself froze and left a...
You are going to have to replace your LCD screen. If you are technically astute, then there are instructions that I can send you... if not , then taking it to a shop would be your best bet.
Jun 30, 2008 | Computers & Internet
Dell Inspiron 710m Notebook Logo
6,771 people viewed this question
Ekse
Clive
Clive
