Question about Philips LX8000SA System
Lx800sa phillips dvd works but can not play audio tv stations threw this unit got used checked all connections ok tv is a samsung
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Posted on Jun 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Posted on Sep 04, 2008
wings_it
  • 141 Answers
SOURCE: connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Posted on Dec 23, 2008
SOURCE: Picture but no sound with either DVD or CD
Hi
Fixed the problem.All I did is plugged the DVD player in to another DMIA input on the Telly and that some how fixed the problem.I am not techinical enough to explain this but it worked.
Thank you for the interest. Regards Jim.K
Posted on Jan 27, 2009
How to connect a play station 3 to tv?
Just plug it like a regular DVD player thru HDMI connection and then choose HDMI AV input from your TV to be able to see the screen. You can also use the TV as a monitor by using the S-Video or the VGA input and then put the audio of the PS3 to your Audio system or amplifier.
Feb 02, 2011 | Samsung HL-S5087W DLP TV
Getting dvd player to work
OK from your DVD player connect the Composite video output jack of the DVD player marked in yellow to the composite video in of the TV. The connect the audio output (red and white) to the audio input of the TV. Then set the TV to connect to the composite port should have at least AUX1.
Oct 09, 2007 | Philips DVP5140 DVD Player
I have just bought the samsung ht c555 home cinema kit connected it to the the tv all is working well when playing a5.1 dvd but ihave no sound out of the system when on ordinary tv how do you get all 5...
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Dec 24, 2010 | Samsung Audio Players & Recorders
My RX V640 is 5 years old..no problems...no changes to the configuration. when I use to the DTV/Cable setting HDTV..video feed...stereo sound etc is fine. Lately when I try the DVD setting to record TV to...
theb best way to do this is to connect the DVR to the vhs unit and the vhs unit to the tv using red white and yellow for both connections. usually composite video 1,2,3 or 4. DO NOT involve the AVR at all, as it will cause your video and audio to be out of sync.The video will not be as sharp, until you play it threw an up-converting dvd or AVR.
Aug 19, 2009 | Yamaha RX-V640 6.1 Channels Receiver
Issue playing audio from AcerTravelMate6593 on Phillips37PFL7603D
You need to run the audio out to an amplifier such as a stereo unit. The computer doesn't have enough power via the line out to make the TV pick up the sound by itself unless you turn the volume all the way up and maybe not even then, so an amplifier is your answer. It work for me.
Aug 17, 2009 | Acer TravelMate 6593-6656 Notebook
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Philips LX8000SA System Logo
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
