My Efel Harmony oil stove won't light. In recent months it would get very very sooty and then the other day it wouldn't light. I gave it a good cleaning and the soot was unreal, but it still won't light. When we first got it 8yrs ago it hardly made any soot. We had a flexi flu fitted in the chimney before we had the stove fitted and they said the chimney wold never need to be cleaned. Could the chimney be full of soot?
Therinnaiguy
  • 1420 Answers
SOURCE: montgomery ward oil furnace
Use a flexable wand and get as much debris as you can. I would not be too concerned with the insulation unless you see that it looks burnt. Open as many ports you can find and clean where you can. I sometimes inject air from an air compressor at the same time. It makes a mess but gets things moving.
Posted on Sep 15, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Black soot on inside window
2 things cause soot, too much gas or not enough combustion air. Check gas pressure and check your air inlet for restriction.
Posted on Dec 21, 2009
SOURCE: i hahe a double pod efel oil stove, how do i
besem ab wold womenefs kudus ahadu amlak amien
Posted on Feb 20, 2010
  • 37 Answers
SOURCE: Have an efel oil stove, it lights ok but the crown
The gas orfeces are pluged up you need to take a wire brush and cleen them.
Posted on Jan 21, 2011
muntejaya
  • 10421 Answers
SOURCE: just looking for any info. on efel harmony 3 wood
Please get it here : www.fireplaces-oldham.co.uk/Euroheat_Harmony_Classic_Multi-Fuel_Stoves.htm
Multi-fuel > Nestor Martin">www.murphyheating.com > Multi-fuel > Nestor Martin
Kind regards, Jay
Posted on Feb 20, 2011
I was inquiring about how to obtain an owners manual for the Harmony l oil stove
Google this and you will find pdf
Harmony l oil stove
Oct 02, 2014 | Ovens
Efel oil stove wont burn blue only yellow
Pull the crown and the two crown supports, scrape and vacuum the residual ash on the bottom and around the starter coil. Pull the and turn the oil feed tube scraper back out of the way. Reach inside the tube with a screwdriver and scrape out the residue until as clean as posssible. Exercise the fuel tube rod several times until there is no scraping sound. Vacuum the interior and replace the parts (Do not clean the crown).
Dec 23, 2012 | Cars & Trucks
Laptop won't power on. It worked 1 day after picking it up from repair service with Conn's because it is a few months over warranty. They gave me a new cable cord, and when it is plugged up, the...
make sure the lead and plug are good and its plugged in securely if same take it back and complain about it it should work after 2 days of recieving it back
hope this helps
Aug 01, 2011 | Computers & Internet
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Sep 13, 2010 | Heating & Cooling
St.croix pellet stove
your either burnig the wrong type of fuel, or the fuel you are burning is wet, not burning hot enough resulting in cloudy door
Feb 03, 2009 | Kitchen Ranges
Hot poinbt gas stove , mouse inside,
We had this happen recently. The smell of urine got to be too much. My wife wouldn't even go into the kitchen. I took the stove apart. the insulation under the range, which is where he was living, was soaked in urine and **** .I removed all the insulation. Spoke to a repair man. Replaced insulation with pink house fiberglas insuation and gave it a good cleaning. Smeel is gone. Repairman said this happens all the time and is a an easy but labor-intensive job. Call someone to do it if you aren't comfortable taking your stove apart.
Oct 22, 2008 | Kitchen Ranges
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
