Question about Garden
Workforce 163cc ohv repair
Just won't start, when i pull the rope it doesn't make any sounds like it wants to start either
4 Suggested Answers
SOURCE: I can't find my manual and no longer remember what
Does your pressure washer engine have a place to add and check the oil level? If it does. And it looks like the picture from your question. It is a four stroke engine and the fuel doesnt need added oil.
Northstar washers are available online at Central Power Equipment.
You might find an electronic owners manual there.
Posted on Jul 19, 2010
H2_Brad
  • 425 Answers
SOURCE: fairly new gas pressure, was working fine when ran
If you tip the unit the wrong way you can get oil into the head area which will cause a hydro-lock as the piston can not compress a liquid. Pull the spark plug out and then try to pull on the recoil rope. Make sure you are not near the spark plug hole because if there is oil in there it will spray out.
Posted on Jul 16, 2011
  • 6468 Answers
SOURCE: how much oil in ryobi rpw 2400 power washer engine?
they take from a half a quart to a full quart
Posted on Aug 12, 2012
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Pull start rope is hung up and won't release on my ryobi s430
a broken spring a tangled rope a stuck ingaugement tab
Aug 10, 2012 | Ryobi Garden
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Gx160 pull cord rope broken
1. Buy a starter repair kit or get five feet of nylon rope similar to what was in the starter from a Lowe's, The Home Depot or the like.
2. Remove the three bolts holding the starter on the motor and remove any remaining rope on the pulley.
3. Line the hole in the pulley up with the hole in the starter housing and thread the rope through both.
4. Tie a tight knot in the end of the rope and cut the tail off so it won't interfere with motor but not so short the knot comes undone.
5. Thread the other end of the rope through the t-handle and tie a knot in the very end so the handle won't come off and the rope won't be pulled into the starter during the next part.
6. Pull the rope up between the starter housing and pulley and get the rope into the notch in the pulley. Turn the pulley clockwise with the rope in the notch to put tention on the spring. Give it four turns.
7. When the notch gets back to the hole in the housing, hold the pulley and pull the rope back into place from outside the housing.
8. Let the pulley turn slowly so it retracts the rope.
9. You want four windings on the pulley and the t-handle to be held against the housing. If you don't get four windings on the pulley, give the pulley another tension turn (Step 6). If you have four windings and the t-handle isn't held against the housing or you get more that four windings, shorten the rope at the t-handle.
10. Reinstall the starter and you will be back in business.
Mar 06, 2012 | Honda Garden
Starter rope on walk behind mower is hard to pull so mower won't start
Pull the spark plug out and give it a pull. It should pull VERY easily. You could have a vapor lock inside the cylinder and this will clear it. If it still doesn't pull easily with the plug removed then you've probably either bent the crank shaft or seized the engine, due to a lack of oil in it. Hope this helps. Best of luck.
James
Sep 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
The problem the pull rope on a Homelite blower UT08934D doesn;t always retract. While working on it i found that the rotor was loose on the shift. I tighten the nut but didn't seem go all the way...
The Homelite/Poulan starter mechanism is of poor engineering and design. Problems with them are constant in the industry. They seem to work sporadically at best. If you have taken it apart, you have seen the inferior workmanship. Granted, all metal construction would wear also, but would be more heavier-duty and last longer. Another reason (the main one) why they don't last if from working the starter/recoil unit so much because the engine won't start. And when it doesn't, 9 times out of 10, it is a fuel system (carburetor) problem. Pulling on the wimpy unit 50 times so it can start once greatly reduces it's life expectancy, and overuse is the main reason they fail.
Aug 12, 2011 | Garden
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Jul 06, 2011 | Echo CS400 18" Chain Saw
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
The coil rope broke I would like to know how i can repair it. Generator 5500 watt champion.
If I understand correctly, you have a pull-start generator.
The rope to the pull-start broke.
This happened to us out on the job one day.
Our equipment might be different than yours. Our pull-start assembly is held with 4 bolts. Simply remover those bolts and lift off the cover ... carefully. The rope is attached to something I will call a pulley. The rope wraps around the pulley several times.
Do not lift out the pulley that the rope attaches to >> or the spring that re-winds the rope will come un-sprung (at least it did on our machine). If the spring comes unwound, then you got another job, and have to put the spring back also. Your machine might be different.
Keep pulley in place. Remove rope. Get another rope with same diameter and length and put it in.
Oct 18, 2010 | Champion International Champion Power...
Garden Logo
328 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
