Question about Philips 43PP9202 43" Rear Projection Television
Problem with wacthind dvd in full screen and black dot on screen
Hi hows it going i just brought this tv of a guy for 500 dollars and when i got it it had a black dot on the screen about the 3rd of a five cent peice about 10 centermetres from the top right and about 10 centermetres down as well it looks like a texter mark inside the screen but its not do u think something maybe got onto the lense inside the tv im not sure and also when i go to wacth a dvd i get half the tv and half the dvd player i cant wacth the dvd in full screen the tv is always on half the screen can u please help me or let me know how much to fix thanks so much for your time have a great day
    Genius:
  • 1,153 Answers
Not sure I understand the half of the tv and half of the dvd player. Are you saying about mid way of your set is cut off and like the bottom half you have a picture and the top no picture? I can explain the dot, first you can open back of set and maybe take off hole back bezel. Get where you can put your head down in front of C R T's (tubes) and look down in them and see if you see the same thing in one or all three of the tubes. If so this explain the dot. The half problem sounds like vertical is missing. Not sure yet! Need feed back
Posted on Sep 13, 2007
Replace a broken screen on a pn60f5500
It will be best to buy a new TV; instead of replacing its LCD screen; as it might cost 2/3rd of the total cost of a new TV.
Feb 25, 2015 | Samsung 60" Series 5 Plasma HDTV -...
Blue dots in screen . does that mean the lamp is going ?
Hello
I dont know of a good way to tell people bad news. The problem with the blue dots is expensive. A part called the optical block is failing. In general, the optical block takes the red green and blue pictures from the little lcd screens and puts everything togther perfectly. This requires several mirrors, filters, lcds, and parts that I dont even know the names of.
Buying a brand new optical block is a 1000 to 3000 dollar thing. To have the block rebuilt is about 350 dollars.
Sony has been trying to make the customers who purchased these tv's happy by providing extended warrentys, or giving them a special deal on a similar sized new LCD tv.
I would try to complain to sony and see what you can get accomplished. If you do opt to repair the optical block the odds are that it will happen again in a few years. Ebay and the chicago craigs list are where I have seen the guys who are capable of rebuilding those blocks.
I am sorry for the bad news.
Nov 25, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
The tv powered off while i was watching it. The green light power button come on for about seconds and goes off but the tv want come back on or show a picture
LOOK THIS GUY UP ON EBAY STORES HE JUST FIXED MINE , FOR THE HOLE SCREEN HAD LITTLE WHITE DOTS , EVERYONE I ASK ABOUT THE POBLEM TOLD ME IT WOULD COST ABOUT 750-1000 DOLLARS THIS GUY NEW WHAT WAS WRONG RIGHT AWAY AND ONLY CHARGED ME 150.00 BUCKS , AND NOW MY TV LOOKS BETTER THAN IT DID WHEN IT WAS NEW, HERS HIS INFO, HONG BUI TVBSERVICE HOUSTON TX 713-401-7701
Aug 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Suppose 1011 amt convert in words like 'One
Hiii
  1. Start Microsoft Excel.
  2. Press ALT+F11 to start the Visual Basic Editor.
  3. On the Insert menu, click Module.
  4. Type the following code into the module sheet. Option Explicit
    'Main Function
    Function SpellNumber(ByVal MyNumber)
    Dim Dollars, Cents, Temp
    Dim DecimalPlace, Count
    ReDim Place(9) As String
    Place(2) = " Thousand "
    Place(3) = " Million "
    Place(4) = " Billion "
    Place(5) = " Trillion "
    ' String representation of amount.
    MyNumber = Trim(Str(MyNumber))
    ' Position of decimal place 0 if none.
    DecimalPlace = InStr(MyNumber, ".")
    ' Convert cents and set MyNumber to dollar amount.
    If DecimalPlace > 0 Then
    Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _
    "00", 2))
    MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
    End If
    Count = 1
    Do While MyNumber <> ""
    Temp = GetHundreds(Right(MyNumber, 3))
    If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
    If Len(MyNumber) > 3 Then
    MyNumber = Left(MyNumber, Len(MyNumber) - 3)
    Else
    MyNumber = ""
    End If
    Count = Count + 1
    Loop
    Select Case Dollars
    Case ""
    Dollars = "No Dollars"
    Case "One"
    Dollars = "One Dollar"
    Case Else
    Dollars = Dollars & " Dollars"
    End Select
    Select Case Cents
    Case ""
    Cents = " and No Cents"
    Case "One"
    Cents = " and One Cent"
    Case Else
    Cents = " and " & Cents & " Cents"
    End Select
    SpellNumber = Dollars & Cents
    End Function
    ' Converts a number from 100-999 into text
    Function GetHundreds(ByVal MyNumber)
    Dim Result As String
    If Val(MyNumber) = 0 Then Exit Function
    MyNumber = Right("000" & MyNumber, 3)
    ' Convert the hundreds place.
    If Mid(MyNumber, 1, 1) <> "0" Then
    Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
    End If
    ' Convert the tens and ones place.
    If Mid(MyNumber, 2, 1) <> "0" Then
    Result = Result & GetTens(Mid(MyNumber, 2))
    Else
    Result = Result & GetDigit(Mid(MyNumber, 3))
    End If
    GetHundreds = Result
    End Function
    ' Converts a number from 10 to 99 into text.
    Function GetTens(TensText)
    Result = "" ' Null out the temporary function value.
    If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19...
    Select Case Val(TensText)
    Case 10: Result = "Ten"
    Case 11: Result = "Eleven"
    Case 12: Result = "Twelve"
    Case 13: Result = "Thirteen"
    Case 14: Result = "Fourteen"
    Case 15: Result = "Fifteen"
    Case 16: Result = "Sixteen"
    Case 17: Result = "Seventeen"
    Case 18: Result = "Eighteen"
    Case 19: Result = "Nineteen"
    Case Else
    End Select
    Else ' If value between 20-99...
    Select Case Val(Left(TensText, 1))
    Case 2: Result = "Twenty "
    Case 3: Result = "Thirty "
    Case 4: Result = "Forty "
    Case 5: Result = "Fifty "
    Case 6: Result = "Sixty "
    Case 7: Result = "Seventy "
    Case 8: Result = "Eighty "
    Case 9: Result = "Ninety "
    Case Else
    End Select
    Result = Result & GetDigit _
    (Right(TensText, 1)) ' Retrieve ones place.
    End If
    GetTens = Result
    End Function
    ' Converts a number from 1 to 9 into text.
    Function GetDigit(Digit)
    Select Case Val(Digit)
    Case 1: GetDigit = "One"
    Case 2: GetDigit = "Two"
    Case 3: GetDigit = "Three"
    Case 4: GetDigit = "Four"
    Case 5: GetDigit = "Five"
    Case 6: GetDigit = "Six"
    Case 7: GetDigit = "Seven"
    Case 8: GetDigit = "Eight"
    Case 9: GetDigit = "Nine"
    Case Else: GetDigit = ""
    End Select
    End Function
Hope this will solve ur problem
Regards.
G'Day
Sep 10, 2009 | Microsoft Office Professional 2007 Full...
How to convert numbers into words in MS excel?
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Option Explicit '**************** ' Main Function * '**************** Function SpellNumber(ByVal MyNumber) Dim Dollars, Cents, Temp Dim DecimalPlace, Count ReDim Place(9) As String Place(2) = " Thousand " Place(3) = " Million " Place(4) = " Billion " Place(5) = " Trillion " ' String representation of amount. MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none. DecimalPlace = InStr(MyNumber, ".") ' Convert cents and set MyNumber to dollar amount. If DecimalPlace > 0 Then Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _ "00", 2)) MyNumber = Trim(Left(MyNumber, DecimalPlace - 1)) End If Count = 1 Do While MyNumber <> "" Temp = GetHundreds(Right(MyNumber, 3)) If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars If Len(MyNumber) > 3 Then MyNumber = Left(MyNumber, Len(MyNumber) - 3) Else MyNumber = "" End If Count = Count + 1 Loop Select Case Dollars Case "" Dollars = "No Dollars" Case "One" Dollars = "One Dollar" Case Else Dollars = Dollars & " Dollars" End Select Select Case Cents Case "" Cents = " and No Cents" Case "One" Cents = " and One Cent" Case Else Cents = " and " & Cents & " Cents" End Select SpellNumber = Dollars & Cents End Function '******************************************* ' Converts a number from 100-999 into text * '******************************************* Function GetHundreds(ByVal MyNumber) Dim Result As String If Val(MyNumber) = 0 Then Exit Function MyNumber = Right("000" & MyNumber, 3) ' Convert the hundreds place. If Mid(MyNumber, 1, 1) <> "0" Then Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred " End If ' Convert the tens and ones place. If Mid(MyNumber, 2, 1) <> "0" Then Result = Result & GetTens(Mid(MyNumber, 2)) Else Result = Result & GetDigit(Mid(MyNumber, 3)) End If GetHundreds = Result End Function '********************************************* ' Converts a number from 10 to 99 into text. * '********************************************* Function GetTens(TensText) Dim Result As String Result = "" ' Null out the temporary function value. If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19... Select Case Val(TensText) Case 10: Result = "Ten" Case 11: Result = "Eleven" Case 12: Result = "Twelve" Case 13: Result = "Thirteen" Case 14: Result = "Fourteen" Case 15: Result = "Fifteen" Case 16: Result = "Sixteen" Case 17: Result = "Seventeen" Case 18: Result = "Eighteen" Case 19: Result = "Nineteen" Case Else End Select Else ' If value between 20-99... Select Case Val(Left(TensText, 1)) Case 2: Result = "Twenty " Case 3: Result = "Thirty " Case 4: Result = "Forty " Case 5: Result = "Fifty " Case 6: Result = "Sixty " Case 7: Result = "Seventy " Case 8: Result = "Eighty " Case 9: Result = "Ninety " Case Else End Select Result = Result & GetDigit _ (Right(TensText, 1)) ' Retrieve ones place. End If GetTens = Result End Function '******************************************* ' Converts a number from 1 to 9 into text. * '******************************************* Function GetDigit(Digit) Select Case Val(Digit) Case 1: GetDigit = "One" Case 2: GetDigit = "Two" Case 3: GetDigit = "Three" Case 4: GetDigit = "Four" Case 5: GetDigit = "Five" Case 6: GetDigit = "Six" Case 7: GetDigit = "Seven" Case 8: GetDigit = "Eight" Case 9: GetDigit = "Nine" Case Else: GetDigit = "" End Select End Function To use this UDF push Alt+F11 and go Insert>Module and paste in the code. Push Alt+Q and save. The Function will appear under "User Defined" in the Paste Function (Shift+F3).
Jan 19, 2009 | Microsoft Excel for PC
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Red dots on the screen
do they look like pixie dust...or sparkly?....if so I can give you a procedure to get rid of that
Jan 13, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Red dots on a black background
Try to adjust the Vs down about 5-10V.
Jan 05, 2008 | LG 42PC1DA 42 in. Plasma HDTV
Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Oct 09, 2007 | Dell E173FP 17" LCD Monitor
Blinking red light 5 times
This problem is due to moisture content in the flyback transformer surrounding area. Due to this moisture content screen control voltage is changed. Without getting a exact voltage the indicator will not stop. 5 times blinking is only for screen malfunction. Make one general service by cleaning the deflection area and adjusting screen control the problem is solved.
Sep 13, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
