Question about AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t has no sound
Same problem as him. The Amp lights dim to the music base, but the speakers don't make any sound. The power has a 100A as the fuse for the amp, is this correct? Could that be the problem?
  • 883 Answers
If you are getting amp lights to turn on at all, then power is getting to the amp so although the fuse is oversized (50 amp fuse ok), it is not your present problem. I am guessing the final stake transistors have failed. do you know how to test them...you can use a multimeter that has a transistor test function, but first de-solder two of the 3 pins from the pcb...be aware that power MOSFETS may exist that cannot be tested with this meter.
Posted on Aug 10, 2007
  • Marty marty Aug 10, 2007
    by the way, if you do fix this, reduce your fuse size.
SOURCE:
Bumps good but every 10-15 min of bumping it
to much power hooked up to it take something away
Jul 21, 2010 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t amplifier in protection mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Dec 21, 2009 | AudioBahn A8002T Car Audio Amplifier
Audiobahn A8002T wont turn on
try the power wires make sure they r grounded properly or won't work
Jun 29, 2009 | AudioBahn A8002T Car Audio Amplifier
Audiobahn A8002T fan
Hello warneyjacob,
While I was not able to find a part number or support information at audiobahn's website, and the ampguts site did not show the A8002T, several of their amps seem to use a standard muffin fan.
If you can measure the fan, it's very likely that you can find a suitable replacement here. If they do not have one with the exact connector you need, use the connector that is on your noisy fan. Just make sure that the fan you choose is the appropriate size.
Hope this helps. If it does, please rate as "FixYa".
Apr 23, 2009 | Kenwood KAC-7201 Car Audio Amplifier
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
I need a diagram for my A8002T Amp anyone have one?
check out audiobahn.com thier is a free wiring diagram under tech support
Mar 22, 2009 | AudioBahn A8002V Car Audio Amplifier
Audiobahn A8002T
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Let me know if you have any other questions.
Jul 23, 2008 | AudioBahn A8002T Car Audio Amplifier
Audio system makes extra noises... pops
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
Sep 05, 2006 | AudioBahn A8002T Car Audio Amplifier
AudioBahn A8002T Car Audio Amplifier Logo
140 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
Professor_V
Professor_V
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
