Question about Waterway Pool & Spa
New Pump keeps shutting off after a short time
    Top Expert:
  • Waterway Master
  • 4,292 Answers
Bad motor overheating replace pump
Posted on May 01, 2016
PCM problem or what??? My 04 Jeep keeps shutting down due to fuel pump not working. New pump but no current to pump.
Could have an intermittent situation with the pump itself. Did you check that out? Check all connections for corrosion.
Oct 02, 2016 | Jeep Cars & Trucks
My pentair 2 hp challenger pump turns off after 4 second
since it's a new install is voltage set correct on motor ? this seems possible due to short run time you report
May 04, 2014 | Pentair 2 hp Challenger Pump
Fuel pump keeps blowing fuses
The fuse is designed to protect your wires from melting due to current overload. faulty fuel pumps may use more power before failure, so Cody change your fuel pump and filter, the result will amaze you
Jan 03, 2014 | GMC Cars & Trucks
When I turn on the gas keeps on shutting off, I have to keep on turning on and pump gas a lot of times before I can drive car
Have you tried a new gas filter? If a new one doesn't help, have the fuel pressure checked. It may be a failing pump.
Feb 17, 2012 | Volkswagen Jetta Cars & Trucks
After a half hour drive my car shuts down turns right back one ,,but will keep shutting off, feels like its not getting gas, already change the fuel filter check the fuel pump presure is fine whats next
Possibly the coil module under the coil packs gets hot and shorts out because it's on the engine, ( dumb design). I have seen that happen many of times.
Jun 12, 2011 | 2003 Chevrolet Cavalier
Keep blowing the ecmb fuse in my 1991 s-10
check your grounds & the fuel pump connections.the ground should run to the right rear of the motor. look at the wires back to the motor on the frame for anything that may have nicked a wire or a rub thru. You have a short and i belive it shut down if you hit a bump. loose or fraid wire some place. Best of luck & keep us posted on your fix.
Mar 10, 2010 | 2000 GMC Jimmy
95 tahoe lost power while driving now wont start fuel pump is engaging
Is the check engine light on? If so, rent a scanner and read any code(s). Follow the clues to repairs. Does the fuel pump continue to run? It should only run for a short time at key-on, then shut off after building pressure. Likely, new pump time. It wouldn't hurt to install a new fuel filter as well if not already recently replaced.
Sep 06, 2009 | 1995 Chevrolet Tahoe
Pool & Spa Logo
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
