Question about Kitchen Appliances - Others
Kitchen Aid Burr Grinder
Fixing my Kitchen Aid burr grinder Model KPCG100. Have removed the motor. There is a plastic housing covering what appears to be two sets of plastic gears some of which have broken off....hence the horrible grinding noise when I use my grinder. Are these gears part of the motor assembly? They are not listed in the parts list.
    Top Expert:
  • Kitchen Appl... Master
  • 34,711 Answers
If the parts are not listed separately, the motor and gears are a completely separate assembly. A replacement motor (assembly) would include the gears
Posted on May 06, 2013
  • Paul Sawatsky
    Paul Sawatsky May 27, 2013
    I ordered and received a new motor. It does not include the gear assembly. Why is this gear assembly not on the parts list?
2 Suggested Answers
  • 102366 Answers
SOURCE: I would like to see the product manual for "Waring
http://www.waringproducts.ca/en/pdf/ibs/mg100nc_en.pdf
Posted on May 20, 2011
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Dec 21, 2015 | Coffee Makers & Espresso Machines
I need new blades for my grinder. How do I find them?
Go to kitchen aid website under service and support. After that enter your modal number and you will get parts list Thanks Please rate my work
Sep 02, 2011 | KitchenAid KPCG100PM Electric Burr Grinder
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Kitchen aid burr grinder adjustments
You are correct, the grider positions are locked internaly so the grinder will not go too fine since this can damage the blades and also too fine need more power from motor and also can block it by rottating normaly. However you ir open the grider you can overcome the lock and udjust so the grinder can grind more fine coffee. In order to be always at the safe side just move gradualy step by step until you find the perfect grinding and adjust so that will be the minimum plus one mor move for furure adjustment if you need.
Just for reference the corect grinding is for 7 to 7.5 gr of coffee the running time of the coffee from your machine should be 25 sec for 25 cc of coffee aprox.
Good luck.
Rember to vote for this answer.
Mar 02, 2010 | KitchenAid KPCG100PM Electric Burr Grinder
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Gaggia MDF Electric Burr Grinder
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Aug 18, 2007 | Gaggia MDF Electric Burr Grinder
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
