Question about Refrigerators
Ge gsl25jfta bs
Refrigerator won't work anymore after power goes out. What's wrong? Happened two times already
2coolrick
  • 560 Answers
SOURCE: GE side-by-side PS123SGMD BS won't cool
Check the door seals to be sure they are in good working order. Close both doors on a dollar bill at several locations all around the door and pull on the dollar bill. You should have resistance as you pull it out in every area you check. If you have any gapped areas and it slides easily, adjust the door or replace the seals. Also, is the circulation fan in the freezer working correctly? Lastly, unplug the unit for 5 minutes to allow the control module to reset itsef. Then plug it in again and reset your temps, clock etc.
Posted on Jul 31, 2009
aasc
  • 1606 Answers
SOURCE: where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Posted on Sep 12, 2009
arikrom
  • 528 Answers
SOURCE: ge refrigerator GSL251GRB BS WATER / ICE
the clicking sound can come from the mother board in the back, there are several relay's that control the refrigerator function.
Posted on Jan 20, 2010
  • 101 Answers
SOURCE: The water on the freezer
water line frozen in door ge has a repair kit for it
Posted on Sep 12, 2010
carmin77
  • 113 Answers
SOURCE: The freezer temperature on my GE profile side by
Start with the easiest possible problem to solve. Clean it. Not the inside, not the front door; clean the outside, the underside, the back side, the compressor area.
A fridge does not produce cold. It moves heat from the inside to the outside. Step one is to make sure that heat can be released into your kitchen verses sitting in a layer of insulation.
:o).
Posted on Jun 04, 2011
Ge GSL25JFTA is leaking water on the floor from the front of the unit
Turn off the water supply to the ice maker. If it stops the leak, look for a leaky O ring on the filter. There is a plastic hose that runs out of the front of the refrigerator and goes to the freezer door for the water dispenser. It has a connector near the freezer door lower hinge so the door can be removed easily. That connector can leak as well. There is a condensate pan under the refrigerator that may be over flowing too.
Mar 21, 2015 | GE Refrigerators
I have a GE gsl25jfta bs side by side, the freezer melts ice box then freezes it again.. Making a block of ice
Sounds like you could have a bad mother board. Very common problem with the GE models. It will shut compressor off, than everything starts to melt, then it comes back on. Replace main control board and it should resolve your issue.
Jun 18, 2014 | Refrigerators
GSL25JFPE-BS Side by Side refrigerator compressor and condensor fan isn't coming on
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
May 29, 2012 | GE Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 | Vacuums
The water on the freezer door will not work ice does dispense. this is a ge side by side model GSL25JFTA BS. kbaker23322@yahoo.com
most likely you water solenoid is bad. need to make sure you get voltage(120v) to water solenoid. if voltage then the only other thing that could be wrong besides the solenoid. would be a kinked hose or the line (has a small chance) has frooze inside the door panel if sprung a leak.
Aug 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in door stopped working.
check to see if you have water coming to the refrig. Just crack the supply line slightly. Work your way up as far as you can. It either has an obstruction(dirt) or the solenoid valve has stopped working.
Nov 26, 2009 | Sewing Machines
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
