Question about Led Lenser/Coast/Zweibruder Coast LED Lenser P5 High Performance LED Flashlight HP8405 - 59 Lumens, 1 x AA, Speed-Focus
Battery replacement Cant find a way to open a P5 to change the battery
How to regulator the motherboard? because every time open my system unit cmos setting wrong?
This problem is most likely a flat or nearlt flat BIOS battery.
Replace the BIOS battery, it may be a coin size lithium battery - may be a CR2032 battery.
Dec 28, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Got F 50 code on Whirlpoos Cabrio wash machine. Tub spins, nothing under agitator, replaced control board, nows blows breaker.
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
If basket turns freely,perform the test below..
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
  1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this stepfailed.
  2. Unplug washer or disconnect power.
  3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
  4. Remove the console to access the machine/ motor control assembly. See Accessing& Removing the Electronic Assemblies.
  5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.If visual checks fail, reconnect P5 and P10 and repeat step 1.
  6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
  7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections. S
  8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
  9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
  10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
  11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
  12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repai
Dec 04, 2010 | Whirlpool WTW6200S Top Load Washer
Whirlpool error code F50 who do I call ?
F50 means that the Rotation Position Sensor doesn't sense any movement from the motor.
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.If basket turns freely, go to step 3. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
3. Remove the console to access the machine/motor control assembly.
4. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 5. If visual checks fail, reconnect P5 and P10.
5. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3.Also measure the resistance at the P10 connector between pins P10-1and P10-7 and verify that the resistance is within the range. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range.
6. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
7. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check fails,reconnect the electrical connections, reassemble stator and motor cover.
8. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector.If there is no continuity,replace the lower machine harness.
9. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector.If there is continuity, replace the drive motor.If there is no continuity, replace the lower machine harness.
10. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test.
11. If the Diagnostics motor failed, then the machine/motor control has failed: Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Thank you !!
Aug 12, 2010 | Washing Machines
Error message F50
Thank you !!
Jun 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code Error F50 Whirlpool Cabrio WTW6600SW
  12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Mar 24, 2010 | Whirlpool Washing Machines
Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Aug 18, 2009 | Electrical Supplies
Do I need a backup battery for P5 to fire up?
Backup battery has nada to do with normal operation.
U
got a sick puppy there.
Apr 27, 2017 | Psion Series 5
Unknown bios pass code
Some motherboard passwords can be cleared by unplugging it from all power supply connections and taking out the motherboard battery, the one that looks like an oversized watch battery, if it has one. Another way is to throughly check the board for jumpers that may be labeled "passwd" "bios config" or similar. Remember when playing with jumpers to not change anything you don't understand and to put everything back when you are done.
May 24, 2008 | Tekram P5 T30-A4/20 Motherboard
Led Lenser/Coast/Zweibruder Coast LED Lenser P5 High Performance LED Flashlight HP8405 - 59 Lumens, 1 x AA, Speed-Focus Logo
Top Led Lenser/Coast/Zweibruder Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Led Lenser/Coast/Zweibruder Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
