Question about Pool & Spa
Onga 933 Can't get the impeller off .. Want to change bearings coz ran bait when dry they need changing .. Took 80 percent apart now I'm stuck
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
macdirk
  • 116 Answers
SOURCE: I have a whisperflo. I've ran the motor without
Yes the impeller is screwed on right handed normal thread. *** Info below pasted form one of my other posts *** You need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, (usually 9/16") or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. (you already did this.) It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it.
Posted on Sep 28, 2010
MOTORWIZJ
  • 1340 Answers
SOURCE: i took the pump apart
ya bent,broke the start switch.. oops.. the 2 yellow wires go to the one lug on the capacitor the other lug gets the red.. most cases .. if you do a sarch in your area for pool pump motor repair with free testing.. sounds like a 20$ or less fix.. the switches are tricky on these and can get knocked out of wack easy... hey remember to prime the pump with water before you turn it on !! hope i was of help.. jay the pool pump guy in longwood fl
Posted on May 26, 2011
MOTORWIZJ
  • 1340 Answers
SOURCE: how to change bearings
it's not that easy but it can be done with a gear puller a piece of pipe to install the bearings, only two bolts needed to hold motor together but the must be catty corner from each other.
here is how most all impellers come off, there MIGHT be a screw in the center of the impeller IT SCREWS OFF TO THE RIGHT ! the impeller turns off to the left.. .Jay the pool pump motor repair guy in longwood FLORIDA .. remember to vote for your favorite FIXYA guy ..thanks J ;-)
PS I would suggest you look in your area for your local pool pump repair guy and have him do the repair, if you break something parts can sometimes be hard or impossible to find ! and for a pump bearing job should cost about $75
Posted on Apr 25, 2012
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
HIGH PITCHED SQUEAK! Dries clothes fine. What part?
most likely it is the rear drum bearing,go here,you can see the part and watch the video,it will show you how to change it.
http://www.repairclinic.com/PartDetail/Drum-Bearing/5303281153/1851
Nov 23, 2013 | Frigidaire FER211A Electric Dryer
How to change bearings
Apr 23, 2012 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Onga ltp400 pump , unable to dismantle to change beariings
It's a matter of removing the main casing, impeller, diffuser, seal assembly, baffle, shaft sleeve, fan cowl, fan, motor end shield and rotor in that order - which part of this procedure are you having trouble with?
Jan 09, 2011 | Pool & Spa
I have a 2002 ford f250 7.3 diesel with a drive shaft vibration at around 45mph. It has a 2 piece drive shaft. The large rubber bushing around the drive shaft in carrier housing is somewhat collapsed on...
hello, i have a chevrolet dually, the carrier bearing, in mine was doing this, i took it apart, pulled both driveshafts apart then took carrier bearing off, the bearing inside was dry, plus they had a bblue look to them, bearings was bad, plus rubber around the bearing was dry rotted, there is know way of greasing these bearings because they are sealed, i pull bobcats, tractors, with mine if you use it for a lot of heavy pulling, they dont last a long time, chevrolets carrier bearing is all made together, bearing and rubber is made together, on mine, seems like i paid about 35.00 dollars for mine, spray some wd-40 around driveshaft where it goes into bearing, i had to take a hammer to mine to get it off front drive shaft, it was stuck pretty bad.
Apr 08, 2010 | 2002 Ford F250 Super Duty SuperCab
How do you remove the impeller and mechanical seal off the pump shaft? I am wanting to change the main bearing that sits inside the motor housing of a Onga pool pump PPP750 model.
The impeller is screwed on to the shaft, you need to pull the cover off the end of the motor opposite the pump so you can hold the shaft to keep it from turning. The impeller should unscrew with just hand pressure, most are a standare SAE thread and turn counterclockwise to remove. Hope this helps.
Jimmy
Mar 12, 2010 | Hardware & Accessories
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
How do you pull apart a pool pump to replace the bearing onga pomp
Assuming the pump is at your working table, do the ff;
1.Unscrew the bolts holding the pump case.
2. Take the impeller and the mechanical seal off the
pump shaft.
3. Now you can take the motor off the pump by
unscrewing the bolts holding the motor and pump.
4. Then, you can dismantle the motor by unscrewing
the four long bolts holding it.
5. Take the back plate off and the centrifugal switch
on the shaft. Mark the original location.
6. Now, you can pull the rotor out, by a slight force
at the back plate side of the motor shaft. Note
that the front plate hold the bearing is bolted.
The front plate goes out with the rotor.
7, Now you can change the motor bearings.
To reassemble, the procedure is the reverse of what you just done. Send your e-mail for further assistance.
Jun 28, 2009 | Plumbing
Water leaking
Jan 24, 2009 | Pool & Spa
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Pool & Spa Logo
78 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
