Question about IFB Washing Machines
Pr5 message is displaced in IFB ELITE SX washing machine
While washing today suddenly in the display Pr5 message is displayed and the machine stops.
Master_Tech
  • 770 Answers
SOURCE: 5L error code
I will pull the book and get back to you today
Posted on Jan 27, 2008
  • 52 Answers
SOURCE: kenmore elite HE4t stops washing and displays code
Code F- DL is a faulty door lock.
Posted on Feb 24, 2009
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
  • 662 Answers
SOURCE: it displays a message: dl and stops
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on May 25, 2010
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
the electronic program is corrupt. just use an alternative setting.
Mar 10, 2014 | IFB Washing Machines
PF MESSAGE APEARS ON DISPLAY
the water level malfunctioning
Nov 07, 2013 | LG Washing Machines
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
We have LG FULLY AUTOMATIC WASHING MACHINE MODEL NO. 8018LS 7.0 kg PURCHASED 4-5 YEARS BACK. SUDDENLY TODAY WE GOT SOME PROBLEM IN WASHING MACHINE AS "dE" written on the top of the screen. please...
Door switch fault, either replace door switch required or maybe an adjustment of the switch. Push against door inwards when displaying dE and hold pushed in to see if it goes away to confirm switch problem
Aug 29, 2010 | LG Washing Machines
My washing machine suddenly stoped working today and it is giving me LE sign on my display.
The first thing to do with any electronic controlled product is to unplug it for a few minutes and then plug it back in..Good Luck
May 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
Machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Jun 01, 2008 | AEG Lavamat 88840 Front Load Washer
WASHING MACHINE SUDDENLY STOPS
Thankyou for the reply and service and interest. I managed to solve the problem myself, by down loading info from the tinternet and responding from that.
Thanks to all
DJ JOSH
Apr 27, 2008 | Washing Machines
5L error code
Jan 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
770 people viewed this question
Top IFB Washing Machines Experts
Eric Taylor
Eric Sutherland
Ken Strite
Ken Strite
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
