Question about Canon PowerShot S70 Digital Camera
I cannot look through images or even delete them.
Whenever i turn on my camera, the only buttons that work are the playback, the zoom, and the the button to take a picture. When i press playback, it only shows the picture that I just took. I cannot look through my previous images.
    Problem Solver:
  • 11 Answers
Try upgrading the firmware at your local dealer.
Posted on Aug 10, 2007
SOURCE:
Nikon Coolpix L24 camera. It doesn't take pictures. I mean that camera turns on nicely, the lens unfolds, you can even view images that you previously took, but when you press the button to take new photo,...
Check that your digital camera is not in playback or review mode.
Make sure the memory card is in the camera and that the card is properly formatted.
The Memory Card may be full. Download the images to the computer or delete some to make way for new photos.
Check the charge on the batteries. Replace if necessary.
Have you been using the flash? It may be recharging. When it is recharged, the camera will be ready to take photos again.
Aug 21, 2013 | Nikon Coolpix L24 Silver Digital Camera...
Canon powershot SD870 IS. Once I switched to magnified image playback, I cannot cancel & return to single image playback. Have tried MENU and turning zoom button back.
Problem with firmware [software} ,Please update .
http://www.usa.canon.com/cusa/consumer?pageKeyCode=contactUsLanding
Yo can restart.Replace battery.
Mar 24, 2011 | Canon PowerShot SD870 IS Digital Camera
I HAVE A NEW POWER SHOT SX130 IS (CANNON0 I DO NOT KNOW HOW TODELETE THE DOWNLOADED PICTURES FROM THE MEMORY CARD
You can delete photos from your SX130 IS in two ways:
To Delete Photos Individually:
  1. Press Playback Mode button (looks like a play button and is located on the top right on the LCD-side of your camera)
  2. The last image you took will appear on the LCD screen.
  3. Use the Left & Right arrow keys or turn scroll wheel to cycle through your images
  4. Once you find an image you want to delete, press the Trash button. The image will be erased.
  5. Press the Playback Mode button or the FUNC/SET buttons to exit when done
To Delete ALL Photos
  1. Press the MENU button (bottom right button on LCD-side of camera) to bring up the Menu screen
  2. On the Playback tab (Looks like a Play button icon), use the arrow buttons or turn scroll wheel to scroll down to Erase. Press the FUNC/SET button.
  3. You now have three options Select, Select Range, and All images. Select will allow you to delete individual images, Select Range will allow you to select a series of images, and All images will delete all images from memory. This last one is the option we are looking for.
  4. Use the arrow keys or scroll wheel to choose All images
  5. Use the arrow key or scroll wheel to select OK when the Erase confirmation screen pops up.
  6. Your images will be erased!
Mar 14, 2011 | Canon Cameras
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
How to delete pictures
you can just use the format menu on the setup menu
Dec 13, 2007 | Sony Cybershot S650 Digital Camera
Optical / Digital Zoom
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Touch the Magnifying Glass Icon. Use the Arrow Keys to move around the display area.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Turn the Mode Dial to Playback, then press the "T". Use the Enter button to move around the display area. Press the middle of the ENTER KEY to see your images in thumbnail view and / or scroll through several images at one time to find a specific / special image quickly.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Canon PowerShot S70 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
