Question about Refrigerators
Bush bfff48144 frost free freezer how to find red and green swiyches
kstfas
  • 75 Answers
SOURCE: frost in "frost-free" freezer
Hi, This is my suggestion to check the defrost timer. "I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer." Sound like you have already done my little test so the defrost timer needs replaced. NOTE: Refrigerators are well insulated and it takes several hours to completely defrost one so you may want to try it again. Also, I believe the clicking you hear is the fan blade hitting ice. Hope this helps. Let me know. kstfas
Posted on Sep 24, 2007
eagle338
  • 4889 Answers
SOURCE: freezer no frost
This is probably due to the failure of defrost timer or the heating coil..Try this
1)The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
2)If this doesnt work then Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
Posted on Oct 15, 2007
  • 1122 Answers
SOURCE: frige freezer
if you have frost in the freezer it either has an air leak on the gasket or the defrost system has failed and you need to call an honest appliance repair person,don't call sears$$$$$$$$$,check all around the gasket first,mike
Posted on Sep 12, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Is there a way to disable the frost-free feature on amana freezer
Unplug your refrigerator and open the rear panel in the back of freezer. Disconnect one whire on one end of the defrost heater. Tape the wire up and you'll be good to go no defrost. Sea Breeze
Posted on Aug 19, 2009
  • 48 Answers
SOURCE: freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Posted on Aug 24, 2009
Hi, I have a frost free bush fridge freezer. All of my food has been defrosted. The fridge part is working fine. Any idea if there's something I can do to fix the freezer part? Thanks
turn the temperature dial for freezer to a bigger number and see if it gets colder . if not you might need a repairman to check the freon
Jan 23, 2017 | Frost Refrigerators
I want to know if the fridge automatically defrosts
frost free has a defrost system. except really small units
Sep 14, 2012 | Refrigerators
Bush fridgefreezer frosting up and its supposed to be frost free its a week old.
look at the door gasket to see if any air can get in when the door is closed. It is also possible the defrost heaters are nor working. Get it serviced under warranty or have argos send you a replacement.
Aug 08, 2017 | Refrigerators
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Our freezer has stopped working and the red and green light are showing
is it frost free? if it is then it could be a defrost heater, fan motor or defrost timmer. if it is not frost free then it could be short of gas or the compressor may be on the way out
Apr 30, 2009 | Freezers
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Frige freezer
Sep 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Hot point (iced diamond) model R564P
Red light refers to temperature failure, green refers to mains power normally. If the unit is running continuously then I would suspect gas loss (if not frost free) or defrost problem (if frost free). If it is gas loss you are probably looking at a new unit. If it is a defrost problem then you could try defrosting and restarting unit. I cannot find your exact model so hard to suggest solutions to. Hope this helps.
Sep 09, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
