Question about Alpine Car Audio & Video
Alpine amp 3523
Wires
2 Suggested Answers
  • 3 Answers
SOURCE: alpine 3523 no instructions or wiring
I know this is a little late but I have one and the hookup is very easy, On the right side of the amp there is a six pin plug. Above it it says BATT REMOTE GND. The two pins below BATT are the battery (V+). The pin below REMOTE is the (V+) switched turn on. The two pins below GND are the ground. The rest is simple. Two RCA inputs. The switch to select MONO(R), STEREO, or MONO(L) works as explained. If you want stereo, put the switch in the middle and supply two inputs and two speakers. The MONO(R) and MONO(L) are to select a single input that will supply a single (bridged) output. Connect two speakers and they will supply the same source or connect one speaker to the outer speaker terminals for higher power output. The variable or fixed switch just bypasses the GAIN CONTROL knobs(used for Alpine's 8 pin DIN plug on unit, for older EQ's and head units.
Posted on Oct 18, 2008
How do I bridge this amp to run a single sub?
  • To bridge 1 sub with a Alpine MRV-100M amp you run the negative and positive wires coming from the speaker to the outside terminals on the AMP respectively.
Regards, Tony
May 22, 2011 | Alpine MRV-100M Car Audio Amplifier
When i turn my alpine MRP-M650 amp on there is a click in the sub and then nothing else. when i was driving with volume down low the sub just stopped working.
sounds like a short. did you check the amp fuse and the fuse on the power wire (under the hood) make sure there are no wires touching. most common is the wires to the sub touching on the amp. let me knwo if that helped
May 17, 2011 | Alpine MRP-M650 Car Audio Amplifier
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Alpine Cdm- 7834 wiring help
just use any negative wire you only need one wire from the negetive.
Mar 13, 2008 | Car Audio & Video
Wire diagram
guynoir..with alpine your other set of speakers would most likely run through an amp ,which may connect up by the rca leads or a din plug , this is where your fader comes in to play.i was an agent for alpine
Feb 07, 2008 | Car Audio & Video
Alpine 3523 no instructions or wiring
Jan 15, 2008 | Car Audio & Video
Alpine amp mrd-m605
The amplifier probably has shorted output transistors. If the amp gives the same error message with the speaker wires disconnected from the amp, the amp needs to be repaired.
Dec 30, 2007 | Alpine MRD-M605 Car Audio Amplifier
Car Audio & Video Logo
20 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
