Question about Hoover Washing Machines
Hoover 500md washing machine detergent dispenser
SOURCE: Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Posted on Feb 16, 2008
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
SOURCE: fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Posted on Feb 07, 2009
  • 69 Answers
SOURCE: How do I remove the agitator in a Hoover 500MD
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Posted on Aug 25, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Hi I am experiencing a problem with my hoover washing machine, when the machine is turned on it is not taking the powder from the drawer or filling with water?. It is a Family 1300 mega load hope you can...
There are a few reasons that you are having this problem.
It's possible that the hose that supplies the water is blocked. If the drawer and powder are totally dry, the solenoid that supplies the water to the detergent drawer may be bad. Some machines use hot water to dispense the detergent and cold water to dispense fabric softener, so both must be available to that type of machine regardless of the wash/rinse temperature selection.
I'm not familiar with Hoover. If you open the drawer and see a tab that stops the drawer, depressing the tab may allow the drawer to be removed and cleaned at a sink. They are not dishwasher-safe and must be cleaned by hand.
If this does not help, please repost your question.
Good luck from Detroit, MI, USA.
Jul 19, 2011 | Hoover Washing Machines
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
How do I remove the agitator in a Hoover 500MD machine?
Aug 25, 2009 | Washing Machines
Bad leak
Your first option before anything else is to remove the dispenser tray entirely and clean it thoroughly.
Also clean inside where the fits before replacing.
Quite often there is a build up of old fluids or powders that have congealed and blocked up the inside.
Good luck and thanks for using FixYa.
Mike.
Mar 02, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
dispensers
insert 1).
Dec 29, 2007 | Washing Machines
Detergent not being washed out of dispenser
This suggestion is not too good. If your dispenser opens at the initial stages of the cycle, just a little - pour some water into the dispenser to wash down the detergent. (For my machine i can pull out the dispenser anytime during the wash, except when water comes into the dispenser, but even then i think the water enters the tub.) For this you dont have to hang around the machine for long for it is in the initial stages of the cycle. Later you hv to check the flow of water into the dispenser. Hv no idea how to do it; but i gave you a quick solution.
Mar 01, 2007 | Asko W6021 Front Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
