Question about Garden
Hayter heritage 13 30
Engine cuts out when blade is engaged
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
Posted on Apr 07, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
Cutting blade won't engage
with unit off look under at deck and inspect cable and pulleys and belt adjust and or repair
Sep 28, 2016 | Garden
Hayter jubilee 43
Sounds like the fuel system need to be cleaned out. I woudkl also check for grass clogs and a sharp blade.
Sep 07, 2014 | Garden
Briggs instructions
Locate the drain plug on the bottom or side of the engine (might have a drain pipe attached to it) remove plug let oil completely drain screw off filter and replace (if equipped) refer to manual or Google and find out how much oil the engine holds (maybe around a quart) replace oil check for leaks and go mow your grass
Aug 15, 2014 | Briggs & Stratton Garden
Toro 20056 engine runs but the cutting blade does not engage
you have a Toro and for whatever reason it is listed in the flat panel TV area.
Aug 29, 2012 | Televison & Video
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engine cuts out when engaging clutch or engaging blades..
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
