Question about Whirlpool Washing Machines
Hoover 500md Where to place the detergent in Hoover 500md washing machine
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
  • 12 Answers
SOURCE: Need User Guide for Hoover washing machine
you can download manual from hoover.co.uk
Posted on Mar 27, 2009
SOURCE: hoover quattro system 1100 ab power jet as 110
I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
Posted on Jul 25, 2009
  • 69 Answers
SOURCE: How do I remove the agitator in a Hoover 500MD
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Posted on Aug 25, 2009
Can i use suspension rods from a hoover 500md and put them in a Simpson 750 WMD 68
as both machines are made by electrolux factory, it is a possibility
check the overhaul lengths and the method of fitment
Jan 14, 2018 | Miscellaneous
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
Hi I am experiencing a problem with my hoover washing machine, when the machine is turned on it is not taking the powder from the drawer or filling with water?. It is a Family 1300 mega load hope you can...
There are a few reasons that you are having this problem.
It's possible that the hose that supplies the water is blocked. If the drawer and powder are totally dry, the solenoid that supplies the water to the detergent drawer may be bad. Some machines use hot water to dispense the detergent and cold water to dispense fabric softener, so both must be available to that type of machine regardless of the wash/rinse temperature selection.
I'm not familiar with Hoover. If you open the drawer and see a tab that stops the drawer, depressing the tab may allow the drawer to be removed and cleaned at a sink. They are not dishwasher-safe and must be cleaned by hand.
If this does not help, please repost your question.
Good luck from Detroit, MI, USA.
Jul 19, 2011 | Hoover Washing Machines
How do I remove the agitator in a Hoover 500MD machine?
Aug 25, 2009 | Washing Machines
Cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Feb 09, 2009 | Hoover AAA160 Front Load Washer
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover ws130
take out the detergent drawer and thoroughly clean. if that doesn't work, the may be a blockage in hose from drawer to tub. take off top, remove hose and clean out
Mar 03, 2007 | Broan-NuTone WS130 Kitchen Hood
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
