Ac showing H1 indcation
SOURCE: MY VOLTAS VERTIS PLUS WINDOW AC IS VERY QUIET
It is quiet inside that is normal. But outside also it should make reasonable moderate noise only. Check for any vibrations of wooden, glass, grill or plastic body. Check for balance. It should be tilted somewhat downwards.
SOURCE: voltas vertis gold-i 1.5 sac manual required.
you can visityour nearest Voltas delarship and ask for the mannual or call the customer care for the mannual.
Testimonial: "thanks"
SOURCE: Hi All, My Voltas Split AC
in the pcb board there is a switch called manual switch it will on ur unit just open the indoor flap.
SOURCE: how to unlock voltas vertis
if your remote get locked then simultaneously press your temperature up down keys for some time ....lock will be opened .
SOURCE: voltas vertis error code
Unfortunately, Haier for whatever reason, does not include any of the error codes in their literature. To find out what E3 means and the solution, contact Haier Customer Support 1-877-337-3639, Have the correct model number handy when you call.
I hope this helped you and thanks for choosing FixYa.
Voltas' customer care ...
