Question about Craftsman Garden
Tractor Does not start
I had flush several times the carbulator, check fuel pump, change gas filter, spark plugs, drain gastank looking for water. and tractor does not start. It was working good and them I have this problem since March. Does any body got an Idea of what to do? Other than exorcism.
    Novelist:
    Scholar:
  • 80 Answers
When you flushed the carb did you remove the bowl and clean it?
If not you should try this.
If you did then you should check to make sure you have spark
If you have spark you should check to make sure your idle jet did not fall out when you cleaned the fuel bowl (this can happen very easily and will fall silently and disappear) If it's missing, it will not start no matter how hard you try.
Try those things and repost with what you found if still having problems.
Posted on Nov 15, 2013
da420bmx
  • 4 Answers
SOURCE: 19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
Posted on May 19, 2009
wadembly
  • 475 Answers
SOURCE: Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
SOURCE: 10 year old Craftsman Lawn Tractor won't start
I had a similar problem and found that the float was hanging up on the wall of the carb fuel chamber. I sanded lightly the outer edge of the float and never had the problem again. That was 3 years ago. Having a different problem now. After setting overnight in cold weather, 20's, engine turns over very slowly even with a new battery. Engine starts, but barely. Once running, everything seems fine. After shutoff, engine restarts quickly. Next morning, same thing happens. Anyone have any thoughts?
Posted on Dec 28, 2009
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
  • 13 Answers
SOURCE: I have a John Deere GX345 with a Kawasaki liquid
Sounds like you may have a problem with Choke adjustment, or perhaps a broken choke cable. Do you have a workshop manual?
Posted on Oct 25, 2010
B&s 22hp engine won't start
Hi Charles:
I'd start by checking the spark plug condition and function.
Wet........... no spark
Dry............ no fuel
Check for spark anyway. Hot and blue.
Try priming carb with a squirt of gas.
Drain and flush carb. You may need to remove and thoroughly clean if gummed up.
Jan 18, 2016 | Cars & Trucks
STARTED AND RAN ROUGH AND WONT START AGAIN... NO SPARK
Drain gas completely from tank to ensure no water is in the tank, check for spark with spark tester, if no spark shows with spark tester, re check gap on coil, if points & condenser are present, sand down the gap between the points to ensure a proper connection. Make sure to change fuel filter with a high quality John Deere fuel filter and use fresh fuel... Fuel can "go bad" after 1-3 months, if the tractor is/ left outside chances are there is water in the tank.
Nov 18, 2013 | John Deere Garden
Jd gx345 20 hp kawasaki water cooled. turns over will not start Both coils have juice to bath termals at the same time with the key on or off.
Drain fuel completely from tank, fuel line, and carburetor... Change fuel filter, change spark plug(s) add FRESH gas... Not 1 week, month or year old gas... (Can't be contaminated, or mixed with old fuel) there will be a drain screw on the carburetor (at the side of the bowl) You may need some quick start to get the engine to initially start up and keep it running with the spray until the fuel system fills up with fresh fuel and stays started.
Sep 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Gas was put in tank ,we are draining tank,was only run about 500 feet, what should we do to make sure engine is flushed
Disconnect your fuel line from the Fuel tank, take off the fuel filter and allow it to drain. Renew fuel filter and fill filter cup with diesel. Open line going to the injectors from the filter cup and allow to drain. Turn on the ignition while the line is disconnected and allow the pump to flow clearing any residual gas, do not crank the engine. With the fuel line disconnected from the injector, remove the glow plug relay. Crank the engine several times for 10-15 seconds at a time to cycle the fuel through without spark. Re-connect the fuel lines and replace the relay. Make sure that you have primed your fuel system as if you had ran out of fuel which by this point it already should be. Start the engine and run for 5 seconds, shut off, repeat this start cycle several times and you should be good.
Jun 20, 2012 | 2004 GMC Sierra 2500
Truck will not start when cold - like if not getting gas till several starting attempt and pumping at time the gas pedal.
couple of possibilities; 1) clogged fuel filter 2) Fuel pump going bad not holding pressure. (it drains back overnight or after shut down)
Jan 06, 2011 | 1998 GMC Jimmy
Craftsman garden tractor engine stalls after running for about 20 minutes or climbing a grade
it maybe over heating check fins on sides of motor and clean if needs, another cuase is dirt fuel filter, open gas tank and look to see if there are things or dark spots on bottom of tank, is yes drain clean and flush fuel lines with wd40 change fuel filter if equiped, sediment will settle and inclines or running will move sediment and block fuel flow. when stopped they settle and will run again for time
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 79 firebird that hasn't been used for years. i want to flush all the fluids add new ones, jump the car and see if it runs. i just don't know where to start. how do i do a fluid flush?
ok.. oil simply change it and the filter don't forget to add oil to rubber ring.. water jus unhook the hose at the bottom of the radiator using pliers and make sure you have a drain pan.. you can run water through it if it is unclean, otherwise you shouldn't need to flush, then reattach hose and clamp.. fill to top.. the water pump on the vehicle will need to be rotated or cranked to get water into the engine, and refill... be careful not to crank the water pump by hand because that will mess up the timing and you will need to redo that.. tranny fluid should not be changed because if there is a certain amount of metal shavings already in it clean fluid will ruin it, but i suggest checking the fluid level and maybe topping it off if needed there should be a bolt on the side of the transmission that you can take out and put your finger in the hole and the fluid should reach the hole and no lower if it pours out its fine let it level out too much tranny fluid is just as bad as not enough.. you will need to have the car on jack stands as level as possible to do this... also you can disconnect the fuel lines at the carburetor and connect a hose to it turn the key on and the fuel pump should pump out the old gasoline..
Jul 02, 2009 | 1979 Pontiac Firebird
Long rest
OK, this is what the StreerRodders face all the time.
1) Pull all the plugs and get new ones ready.
2) Drain the Oil and replace with 10W-30 with new filter
3) Check the water level in the radiator - make sure up to level
4) Put several ounces of sea-foam down each cylinder
5) Hand crank engine over several times
6) Use starter motor to spin over motor several more times
7) Put Spark Plugs back in.
8) Make sure fuel in fuel tank is drained
9) Add new premium fuel - Use an air hose to clean the fuel line to the engine
10) Pump through new fuel by loosening the fuel line by engine and pumping a bunch through - hook back up tight.
11) Try starting engine -
12) If Carb engine use a bunch of carb cleaner in the carb before starting to clean out most or junk
13) Once engine is started monitor oil pressure and temperatures carefully - run for about 10 minutes
14) Stop
15) Drain Oil - replace filter again - put in new synthetic oil - recommend Amsoil 0-30W
16) Drain radiator and flush out -
17) Reset radiator fluid and top off.
18) check for leaks everywhere
19) Start again and drive carefully for 100 miles and you should be good to go.
Regards,
Doug
Jul 31, 2008 | 1992 Mazda MX-5
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
