Scanner problems scanner fln3461a
Please solve the problem of 5600/5650 usb scanner please verify that you have UNLOCKED the scanner hardware . The lock is located on the bottom of scanner click ok after you have unlocked the scanner
I have a scanner 5600/5650 UMAX , but it has been started problem since last one week and the scanning of document can not be possible give me solution
May 11, 2012 | Umax Astra 5600 Scanner
Scanner software can't find the scanner anymore
From the menu you have to take the source first
Sources could be scanner, camera etc.
Make sure you have the scanner selected before you try to scan
luciana44
Dec 02, 2009 | Microtek Office Equipment & Supplies
I plug in my cannon lide 20 scanner and it doesn't stop scanning
I had this problem with my old Canon scanner and my new Canon scanner. I mistakenly threw my old scanner away, believing the problem to be terminal, only to find the new scanner demonstrates the same problem. The problem appears on whatever computer I install the drivers on (I have 3 computers). Constantly unplugging and plugging the scanner back into the USB port eventually sorts the problem out, i.e. the scanning arm will go to the 'home' position and stay there waiting for some scanning action.
I presented this problem to technical support of Canon, and this was their response.....
Thank you for contacting Canon.
It appears that your Scanner is receiving commands from your PC to scan. That means that the scanner can only operated when a command is given by your PC, the scanner can not operate all by itself.
In that case we suggest you contact the manufacturer of your PC or Microsoft for further assistance in solving this problem with your operating system.
I hope this information is of use to you.
Well there you go, the biggest example of 'pass the buck' you may have ever seen.
Having been a software enginner and using computers for the last 25 years, I sort of don't believe this - AT ALL. My only conclusion is to get a new scanner and make sure it isn't a Canon.
If you find out the answer to this problem, and I haven't thrown my scanner away by that time, then I'd be interested in it.
Nov 08, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
HP Scanjet 5370c problems
Scanner part of the hardware has gone defective kindly replace the scanner.
Sep 11, 2009 | HP ScanJet 5370C Flatbed Scanner
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
3170 Epson scanner. Never a problem before, but
Turned off scanner. Rebooted computer. Turned on scanner again. Works fine now.
Mar 22, 2009 | Epson Expression 1640XL Pro Flatbed...
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Problems with Umax Astra 1200S Scanner Horizontal stripes when I scan
open the scanner and clean the scanner glass and the scanner lamp if the problem didn't solved change the scanner lamp
Mar 16, 2008 | Umax Astra 1200S Flatbed Scanner
57 people viewed this question
k24674
