Question about Refrigerators
My husband and I recently purchased a new home with all new appliances, and a water softner, but recently we have noticed white flakes coming out of our ice maker...any suggestions on what this maybe caused by are greatly appreciated. Thanks
    New Friend:
    Problem Solver:
  • 12 Answers
I think you have to show the water softener to the technician to get it fixed whatever the problem occur in it because we are new to it and don't have exact knowledge where is the problem or simply you can give call to customer support to get it resolved as quickly as possible.
Posted on Dec 22, 2014
    Top Expert:
  • Refrigerators Master
  • 49,142 Answers
Check the operation of the water softener as the flakes may be calcium deposits. Use only kiln dried softener salt in the unit as pool salt has impurities that will damage the filter medium
Posted on May 06, 2013
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
I have a kitchenaid refrigerator (Model KSRS25ILBL02). The water from the dispenser has some tiny white flakes. I though it's the water reservoir (100' coil tubing) problem. But after I took the...
have you ever changed the water filter that's in the front bottom sticking through the kickplate?part number 4396508 and it's around 45 to 50 dollars
Apr 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
Please help me I have a American Standard whirlpool tub. I have flakes coming outta the tub when the water level reaches the jets.I have bleached the tub turned the jets on, drained the tub and did the...
Are they white flakes? Sounds like you have lime deposits turning loose in the plumbing.
Was the unit purchased and installed new? Maybe the privious owner had a hard water problem.
In either case, you may have to invest in a water softener.
HTH,
Mike...
Dec 07, 2009 | Water Heaters
My ice maker produces ice with white flakes in it, and slowly.
If you also get the flakes with the water from the water dispenser it could be the water chiller reservoir behind the crisper in the fridge. If it's just the ice maker the non stick surface in the ice mold may be coming loose.
Oct 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana side by side
Undissolved minerals can appear when ice cubes are added to chilled drinking water. Freezing tap water causes dissolved minerals to solidify and scatter, giving a cloudy appearance. When ice cubes melt, any undissolved minerals settle to the bottom. These mineral compounds in our drinking water are naturally occurring and safe.
Sometimes we see black particles which can be the non-stick surface of the ice mold flaking off.
Sep 07, 2009 | Frigidaire FRS23R4A Side by Side...
Suzuki forenza losing water rapidly
HAVE YOU LOOKED IN YOUR FLOOR BOARD OR CARPET FOR WETNESS? IF WET ,YOU WILL NEED TO REPLACE THE HEATER CORE
Aug 20, 2009 | 2004 Suzuki Forenza
Why are there white flakes in the ice from my icemaker?
The flakes are contaminants (minerals) in the water. Typically a sign of hard water, such as well water. A GOOD filter is highly recommended to control the contaminants, and must be replaced often for best results. Most hardware outlets as well as appliance dealers offer filters just for this application and should make the ice taste better. While the minerals are usually harmless and some even claim they're beneficial, you should have your water tested periodically if on a well just to be safe.
Jul 07, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My whites are not comming clean and are not a bright white
I don't know if this is a solution to your particular problem but when we wash whites, first, we wash them twice,with hot water, second, we dont use bleach!!! (this will eventually yellow them). Third, we dont use liquid softner. For the whites we use a softner sheet in the dryer. Since we started to use this procedure I have noticed a marked decrease in areas such as under arm stains in white under shirts. I have some that are 2 years old and have no stains or yellowing like this. Hope this helps
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softner build up in recepticle, and black mold forming
The build up is always going to be there as long as your using softener.The way to beat this is 1.add the softener directly into the tub before last rinse.2.Dillute it with water.3.Stop using softener and this cant ever occur./// The fabric softeners brand may make a difference,try another brand .If its watered down its less sticky.
May 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Microwave Oven Interior Paint
Yes, but if this is not fixed, it may flake off and get in your food, or allow grease or food particles to build up on the surface.
The loose paint should really be sanded off, at least.
Then when it's clean and dry, you can apply a little high-temperature appliance paint, available from department stores, home improvement centers, and appliance parts stores.
Aug 15, 2007 | Welbilt MR622W Microwave Oven
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
