Question about Rotora 2003 DODGE RAM 1500 PICKUP RP.08970.1 Brake Pads - Ceramic
Fuse 18 for dash lights keep blowing. Have replaced light switch and instrument cluster
    Problem Solver:
  • 13 Answers
If your fuse blows repeatedly, the circuit is drawing
too much current. Possible causes:
1) short in circuit... frayed wire, accidental circuit board contact with metal frame, solder bridge on circuit board, or wire placement/connection error
2) Too high voltage in circuit can cause excess current
drain
TROUBLE SHOOTING: measure circuit voltage w/ meter. If normal, put amp-meter (with fuse) in circuit
at problem fuse connector and quickly check current.
If very high, trace (look) along current path for location
of a short to ground/frame/etc.
Hope this helps...if this is all Greek, consider looking
for Better Bus. Bureau approved repair shop.
Posted on May 29, 2013
92 roadmaster instrument lights
Oh boy, I just went through this with my '92 Lesabre, took a long time to trace it all down, and wound up splicing in a new wire just to my instrument cluster lights. A short kept blowing fuses somewhere in that circuit.
Down where your feet go, up under the dash at the fuse panel, there is a 15 amp fuse for park/tail lights. When you hit the light switch (for heads or park lights), power is sent to that fuse, and then to the exterior park lights. There is another wire from that fuse (green wire on mine) that also goes up under the dash, and splices to several bulbs-on the radio, on the HVAC controller, on the ashtray light, also one to the under hood lamp, and then one to the dimmer/brighter switch on the dash, the rheostat that controls brightness of interior lights. One of the green splices goes into this switch, and then another wire goes from this switch to the instrument cluster for the gauge and dash illumination. I couldn't find the short, so ran a new wire from the park light fuse to the gray wire to the instrument cluster for the cluster bulbs. I bypassed the dimmer, and left off the HVAC bulbs and ashtray light. Too much trouble to wire them all up, and think my short may have been in the dimmer rheostat.
If you have a voltmeter, pull out the dimmer switch and check for power on those wires, the green from the fuse. The park light must be switched on, or the fuse has no power. There be 8 or 9 wires on that dimmer rheostat-I never did figure out where all of them went. Asked all over a Buick forum, but nobody had an answer.
Dec 02, 2016 | 1992 Buick Roadmaster
1989 chevy s10 ignition/gages fuse keeps blowing
If you think there is a problem with instrument cluster, unplug the instrument cluster, see if it still blows the fuse. Could be a wiring circuit problem, somewhere? Maybe fuse box issue?
Sometimes, I use a test light in place of the fuse, to keep from blowing all my fuses. If the test light comes on, the circuit is going to ground, somewhere. If the instrument cluster is unplugged, then hopefully, that is ruled out.
Oct 12, 2016 | Cars & Trucks
I have a 1997 cavalier z24 that is having some electrical problems. The tail lights, side marker lights, and instrument cluster lights do not work. I've already replaced the fuse, but it keeps...
you have a dead short immediately after the fuse Check wiring for rub points/ pinch points. Check all bulb sockets to ensure that the power wire is not touching earth or the earth wire.
Jun 13, 2013 | Cars & Trucks
Instrument cluster lights blowing fuses in 2002 ford explorer
need to replace the dimmer switch its probably shorted
Feb 27, 2013 | 2002 Ford Explorer
Tail lights and dash lights dont work
The common power source for the tail lights and instrument cluster is the 20A TAIL LPS fuse(s) in the fuse block. BUT, in the case of the instrument cluster, there are actually two fuses with the same identification. Replacement of the fuse with the ORG wire connected should restore the tail lights when you set the turn/hazard/headlight switch to PARK and may restore the instrument cluster lamps. If not, replacement of the second fuse with the two YEL wires connected should solve the problem
Oct 26, 2012 | 1995 Pontiac Grand Am
Dashboard lights do not come on !
check the cluster dimmer switch make sure not turned all the way down to keep instrument cluster lights from glowing brightly.if dimmer switch not turned way down look for blowed instrument cluster fuse.
Dec 03, 2011 | 2006 Hyundai Sonata
Hello, Im a US Marine and dont know alot about automotive but Im not completly numb... My father in-laws 2003 4x4 dodge pick has been blowing fuse #18 which when blown or removed the dash lights go out......
That fuse also supplies illumination to the radio, hvac controller, cup holder and cigarette tray. I think the best thing to do is start unplugging each one of these until the fuse stops blowing. Then plug the last think in that you unplugged to make sure that makes the fuse blow. If you suspect the instrument cluster start with that first.
Sep 28, 2010 | 2001 Dodge Ram 1500 Truck 2WD
2000 ford focus dash lights not working
Check Fuse box Number 30 which is a 10Amp fuse
& number 15 which is a 7.5amp fuse.
you met have a blow fuse.
If good
Did you check the dimmer on the head light switch Pull out to see if you have power on cable color orange / blue. (Pin 9)
If this is good
Pull cluster out to see if you have power on plug pin 3 in instrument cluster this there..
If you have power
than replace the llumination bulb or cluster.
Very rare to find a ground poblem here.
Aug 29, 2009 | 2000 Ford Focus
No Dash Lights, Keep blowing #2 fuse
i would check the grounding wires. have you tried going to higher ampage on the fuse? There is definitely a short somewhere
Dec 07, 2008 | 1998 Jeep Cherokee
Instrument cluster lighting
I have same problem did u get a solution
Oct 17, 2008 | 2005 Chevrolet Silverado 1500HD
Rotora 2003 DODGE RAM 1500 PICKUP RP.08970.1 Brake Pads - Ceramic Logo
51 people viewed this question
Top Rotora Computers & Internet Experts
jeff5may32
Adam Truesdale
Tim Marx
Tim Marx
Are you a Rotora Computer and Internet Expert? Answer questions, earn points and help others
