Question about Canon EOS 600D Rebel T3i Digital Camera
My rebel t3i wont turn on!!!
I have a t3i and my camera will not turn on and the battery is fully charge it worked yesterday and will not turn on today what could be wrong?
I just bought a T3i and only used it 2 days of shooting. On third day, it's not turning on and it's 80 degree's. So not cold weather. Batteries are fully charged. When I put batter in and turn the switch on, the red light comes on for only a second and then nothing! Other times the red light won't even come on, period. As I said, I've only had it 3 days and it's dead....
Posted on Jul 14, 2013
  • 5 Answers
SOURCE: My camera won't turn on. It is an older cannon rebel sx (8mp).
I just got off the phone recently with Canon. I explained the problem to them and they stated that it appears it is due to the cold weather. I saw some stuff on these posts about Christmas Time, etc...They said that most of the time the camera will be ok after it thaws out, but some issues can be caused because of this. One of them is total lack of power. They said that the camera I have has a minimum temperature that it can handle of 30 degrees. This can cause the LCD to freeze, can cause short circut problems, etc...Thus leaving your camera totally in-operable.
The technician tried to help me first rule something out. He had me REBOOT the camera....seems odd to do that if there is no power, huh? Here is how I did mine....
Power on the camera....Remove the battery...then the Disk battery....leave the battery door open for one full minute. Now turn the camera off.....put the disk battery in, then the regular battery....close the battery door....power on. If you have power and your LCD monitor goes on it will say something like 00007 or something like that.
Unfortunately.....Mine didnt. So they are sending me info on my email to send in my camera. It will need to be repaired/replace the parts etc...
I hope that your cameras end up working. They guy from Canon suggested that in the cold weather while carrying it, keep it under your shirt close to your body to keep it warm, dont change lenses in the cold air, and if you are photographing an outdoor sporting event and its cold enough for you to be covered up, then do the same for your camera.....he himself wraps a hand towel around his whole camera except the end of the lens and the view finder (the one you put your eye up against, not the LCD) Wrap a rubber band around it to keep it in place on the lens and unit.
So....like i said, please...I hope this helps.
Keep me posted!!! Would love to hear positive things that your camera has started working again.
Julie
Posted on Jan 09, 2009
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
Gryfox
  • 216 Answers
SOURCE: Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Posted on Nov 27, 2008
RixsFixes
  • 2200 Answers
SOURCE: Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Posted on Aug 09, 2009
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
Canon rebel T3i does not turn on!!
The camera definitely either needs repair or replacement. If it becomes warm to the touch, turn it off immediately and remove the battery, as this could cause a fire.
Apr 17, 2017 | Canon Cameras
Why wont canon t3i screen turn on?
Your camera screen is dead. Get it fixed.
May 24, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Video turns off durning video
Make sure your battery is fully charged. Read all the stuff I wrote about batteries last weeks. Lots of problems occur wham batteries are not ok anymore.
For taking a video, the camera needs extra power, because it is recording and the screen is on all the time. Thaking stills for a camera is like a walk. Taking Video is like running. So it is exhausted sooner.
Nov 26, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My 600D will not turn on however, I can hear beeps when I push the buttons in my cam. How can I fix this?
Make sure with voltage tester battery is fully charged or charge battery for at least 2 hours and reinsert battery and try again. Might have to replace battery and they are cheap on ebay. Rich
Aug 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
unless you put the battery in wrong There is a small diagram on the lid part or in side where the batteries go showing which way the batteries are put in.
May 06, 2013 | Canon PowerShot SD600 Digital Camera
My canon rebel t3i won't turn on after I charged the batteries and this light kept turning on but now the camera won't even turn on .
First try a different battery in your camera.
second try your batteries in someone elses canon (same model)
third go to some one that can check the battery.
Has the camera got wet at all? if so then ther might be internal damage and need to be serviced
Jan 12, 2013 | Cameras
Hi there well i hope i will get help from you my camera canon eos 600d jest stop working with no power at all and battery is fully charged when installing battery nothing happen camera is off
where you put your memory in card if the latch is not closed proper the camara will not turn on same with were your battery goes check to see if their is some thing blocking an make sure it is closeing proper
Aug 28, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Canon EOS 600D Rebel T3i Digital Camera Logo
402 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
