Question about Tappan TEF242 Electric Kitchen Range
Oven will not heat
Broiler works, oven does not, although it indicates on and in preheat
  • 5,645 Answers
Could be fuse.
Posted on May 09, 2013
Oven takes forever to preheat. Only the bottom oven element comes on during preheat.
Try checking the heating elements on the top might have come loose
Apr 22, 2016 | Ovens
No heat
The home's circuit breaker is not the problem if part of the stove / oven works. What is more likely to be the cause is a problem such as an "open" or "burned out" heating element or socket.
The control is "on" and sending power to the element. The control reports "Preheating" but since the heating element itself is no longer a complete circuit - it fails to heat. As mentioned above, it may be a problem with the socket that the heating element plugs into - but could be a problem with any wire between the control and the heating element.
I would suggest shuting off the circuit breaker for the stove / oven. Check to be sure it is off by turning on a heater that worked previously. If it stays off, you're ready to continue. Carefully inspect the heating element itself for damage. The surface of the heater should be uniform - smooth over the entire length. You may not be able yo view the back side of the heater - but you may be able to run your fingers gently over the surface to feel for damage. If damage is found on the surface, this would indicate that a new element is required. Once replaced, you should expect it to work again as new. If unable find damage, removal and inspection of both the oven's socket and heating element contact blades should be done. If found to be burned or damaged, replacement of the socket, heater or both may be needed.
Obtain replacement parts designed for you make and model stove / range. Contact an appliance repair service if unsure how to check / make these repairs.
I hope this helps & good luck!
Apr 27, 2013 | Bosch Kitchen Ranges
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not heat but broiler does.
hello mam please visit the manufacturers website there you can find it.
Oct 08, 2009 | Kitchen Ranges
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Tappan TEF242 Electric Kitchen Range Logo
90 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
