Question about Volkswagen Golf V Vw Scale Diecast Model
2012 Golf has a high rev
Engine has a high rev, car backed down driveway without accelerator,when parking kicked in an threw me into parked car
  • Diane Knight May 09, 2013
    The engine kicks into high gear randomly when backing out of the garage, idling, or changing from the accelerator to the brake. Other cars have stated having such a problem.
    Sergeant:
  • 311 Answers
It has fly by wire throttle actuator.
Sorry.
May have a BIG vacuum leak.
See if your model has a recall notice.
Some do.
Posted on May 11, 2013
Starts missing /large dead stop when accelerating
The missing while accelerating is likely due to ignition coils and/or spark plugs going bad. The missing while in park is a normal thing. The car has a rev limiter that will not allow the engine to rev to higher than 3000 RPM while in park.
Apr 11, 2014 | Lincoln LS Cars & Trucks
Engine idle eratic
vacuum leaks .. high idle solenoid messed up..works with the defrost setting..
Dec 29, 2013 | Lexus RX 300 Cars & Trucks
My 96 ford taurus revs high when starting then works it way from 1500 or more down to 800 but fluctuates from 800 to a little over 1000. When putting car in rverse or drive from park engine revs up to...
You need to clean the IAC again and also the throttle valve and bore, use only CRC brand Throttle body cleaner. After they are thoroughly cleaned disconnect the battery for 5 min's and then drive the car in varying condition for a few days. If that doesn't cure the issue you have more serious problems and will need a scan tool to look into the readings from the MAF, TPS and ECT sensors. High idle cold start is normal then slowly dropping after a few minutes. I assume you never had a check engine light. Correct?
Mar 24, 2017 | 1996 Ford Taurus
2000 Silverado 1500 automatic shifting hard not shifting at all or downshifting
sounds like its time to rebuild it including a new shift valve body
Nov 27, 2012 | 2000 Chevrolet Silverado 1500
Rev counter only goes 2 3000 revs on a new golf match 1.6tdi (red I) 2012
diesel engines don't rev as high as gas engines and electronic controls don't allow over running the engine in neutral
Apr 26, 2012 | 2012 Volkswagen Golf 2.0L TDI 2dr...
Manual transmission
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
--- Car wont downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
---- Transmission will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
----- Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
---- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
------- Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
----- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
------ Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------ Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
------- Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
Feb 29, 2012 | 2004 Ford Focus
My1991 mazda 626 will not rev up over 3000 rpm
DO YOU MEAN WHEN YOU ARE ACCELERATING? Or do you mean sitting and reving the engine? If you are just reving the engine in park then the rev limiter is kicking in.
Feb 07, 2012 | 1991 Mazda 626
My grang cherokee2002 us spec, while driving trnz changes fine but when cick down or full excelrate and RPM reaches 4.5 or 5 engine is loosing power and getting noisy and RPM not going more, while gear on...
You are hitting the rev limiter top range, which cuts off your ignition.
I have a 2001 Grand Cherokee and the problem drives me crazy, but it is the way the car is designed- as soon as you hit the rev limit, it shuts down ignition and your jeep will "buck" - a real pain when you are trying to accelerate into traffic!
You have the 4.0L straight six engine, yes?
If so, please take my advice and learn to live with the minor annoyance of the rev limiter- that engine is IMHO the best Chrysler ever made (nearly "bulletproof"!) and it was so reliable you cannot even get it in a jeep now! For decades, that engine was used in welders, tractors, generators...and yes, jeeps... and it is a favorite among mechanics for its durability!
Feb 01, 2011 | 2002 Jeep Grand Cherokee
Parked on a inclined driveway so I went 2 release da car from park into 2 reverse n the shift won't move at all please help me
Sounds to me like there is too much weight on the "park" gear. Have someone push the car forward a little bit, and do it gently, to release some of the pressure on the transmission, and it should shift from Park without a problem. I highly recommend if parking on an inclined driveway, or any hill, to use the parking brake if it is possible to do so. Good Luck
Oct 19, 2010 | Chevrolet Impala Cars & Trucks
Car: 1992 vw golf mk3 gl 1800cc Stationary rpm is too high when the engine is cold. Revs sometimes without touching accelerator or gets stuck at, for instance, 2500, 3000 rpm. Problem is gone when the...
That sounds like the the temperture sensor. that is what works the revs when the car is cold, is should be at the front of the engine. hope that helps
Sep 15, 2010 | 1994 Volkswagen Golf
Volkswagen Golf V Vw Scale Diecast Model Logo
80 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
