Question about Electrolux 30" Induction Self-cleaning Slide-in Double Oven Electric Convection Range - Stainless-steel
Code e35 There is an E35 error code and can't get it off nor can I get the stove top to work.
3 Suggested Answers
earljohn_boy
  • 3 Answers
SOURCE: machine not running and macke error e35
maybe your washing machine is not been used for a year sodeal with a specialist
Posted on Oct 31, 2012
ioneli84
  • 21 Answers
SOURCE: e35 error code
chec the drain pump, if there is a coin blockingthe whole
Posted on Nov 04, 2012
I have oven electrolux MODL. .EW30IS65JSA ..its has problem error .E35 how I can salve this ??
Hello Awad, thanks for your inquiry!
From what you have described your Electrolux range is displaying an error code of E35. I am not showing that as a valid error code, maybe a digit or the panel is misreading. I would suggest performing a reset on your range to see if that would help clear any faulty codes. You can reset the range by disconnecting the power cord for at least ten minutes. If you continue to experience an issue with your range I would recommend seeking additional assistance from a professional technician. I hope this information is helpful to you. -Matt
May 05, 2016 | Electrolux Ovens
I have a Electrolux front loader and im getting an error code of e35 what does this mean
Signals washer has overfilled, pressure hose or pressure switch most likely
Dec 25, 2014 | Electrolux Washing Machines
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
Sep 28, 2014 | Electrolux Washing Machines
Error code E35 what is this?
switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
May 06, 2014 | Washing Machines
94 q45 what color wires for starter circuit
Solenoid wire is black/white from ign switch to junction block, and black/red from j/b to connector e35 pin 1, red from e35 to solenoid..
Mar 16, 2014 | 2001 Ford Escort ZX2
What is the reset code of toshiba estudio 181
i have toshiba e studio 181 it gives an error of paper size its not accepting any paper size expect A3 size plzz help how to set paper size
Sep 12, 2012 | Toshiba e-STUDIO181
Error code 30 - printer not activated on Cannon 210
E3-3 = Paper jam
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD over current error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Electrolux 30" Induction Self-cleaning Slide-in Double Oven Electric Convection Range - Stainless-steel Logo
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
