Question about Samsung AK59-00104R Remote Control
Program tv
I cant get the green menu button to work it wont allow me to change tv settings to cable.
    Top Expert:
  • Samsung Master
  • 74,459 Answers
Set the remote control with an other code to your device, and check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on May 07, 2013
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Hi am looking an Instruction manual for a DSE LCD TV Model GE6400. This TV was brought at **** smith and it appears to be AWA product but there is no manual for it on there web site What the problem...
A friend of mine has also lost hi manual and can't turn off subtitles - did you have any joy locating a manual? Help would be appreciated.
Jan 04, 2011 | Televison & Video
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: http://www.retrevo.com/support/Panasonic-TX-32LX70-TVs-manual/id/2920dj480/t/2/ if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
Zenith h25w35dt cant unlock auto program
USE ZENITH REMOTE HOLD DOWN MENU BUTTON UNTIL THE OSD DISSAPEARS THEN HIT 9876 ENTER CHANGE P/L SETTING IN FACT. MENU
Apr 08, 2009 | Televison & Video
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
T.v wont go past channel 36
I have not worked on this particular model of Sony. What I will say is for the ones that I have worked on.
If you are on cable, the set should be in the CATV or cable mode.
Go in to the user menu and look for section of the menu for the channel setup. There should be a prompt for auto program.
In almost all of the TV models the original factory remote is required to make any set-up changes in the TV set. What I explained is for TV sets that allow changes to be made from the front panel button controls.
Jerry G.
Nov 23, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Samsung AK59-00104R Remote Control Logo
85 people viewed this question
Henry  Thomas
Henry Thomas
